Feed Ecu
Old Aug 31, 2004 | 10:41 PM
raadracer's Avatar
Arrow Feed Ecu
Browsin round the web...I found this. There is hope!!!
http://www.jt-imports.com/FEED_RX8_Parts_List.htm
Old Aug 31, 2004 | 10:47 PM
another8owner's Avatar
wonder what it can do??? the guage pod is cool too but it is facing the wrong way !!!!
Old Aug 31, 2004 | 10:59 PM
Hymee's Avatar
Race Steward
I'll have a gauge pod to put my boost gauge in!!
Facing exactly the way I want it as well!
Cheers,
Hymee.
Old Aug 31, 2004 | 11:03 PM
^^^^^^^^^^^^I cant wait for your S/C to come out. ^^^^^^^^^^
Old Aug 31, 2004 | 11:07 PM
Hymee's Avatar
Race Steward
Looks like I'll have to get the pod gauges for yours!!
Those "remapped" ECU's look good. I just want the hardware/software to re-map them.
Cheers,
Hymee.
Old Aug 31, 2004 | 11:51 PM
IZoomZoomI's Avatar
Boost needed
the ecu is for the j-spec rx8s... would be pretty useless for rx8s at the states, unless its tuneable..
Old Sep 1, 2004 | 12:24 AM
Hymee's Avatar
Race Steward
It is not a piggyback, it is a replacement PCM. It would only be useless if you couldn't use the "same" fuel, and it wouldn't pass your emmissions. Would it work? Yes. They need to ensure the PCM will work with the BCM on your US cars. You can't just swap PCM's without doing some trickery to re-pair the BCM and the PCM. They are like keyed togeteher.
Cheers,
Hymee.
Old Sep 1, 2004 | 12:48 AM
RX8-TX's Avatar
Senior Geek
Does anyone know what is Feed website's address?
Old Sep 1, 2004 | 01:00 AM
donald121's Avatar
http://www.pac-gate.co.jp/feed/
Well, I sent an email to rotary extreme asking about feed ecu, they said it is only an ecu map. We have to send our ecu to japan and let Feed load their map. Not sure how accurate is my information but that's what I got from rotary extreme.
Old Sep 1, 2004 | 01:11 AM
Neon's Avatar
Black Ace
Yes, its the same here for us. One of our guys intended to send his to R-magic for ECU re-map and the down time is 2 weeks. Unless u got a spare ECU or else rent a ride..:D
Old Sep 1, 2004 | 01:43 AM
takahashi's Avatar
Cheers,
Hymee.
Here did you get it from Hymee?
Old Sep 1, 2004 | 02:18 AM
IZoomZoomI's Avatar
Boost needed
im a lot more interested in their ring and pinion set for the final gear :D
Old Sep 1, 2004 | 09:24 AM
shelleys_man_06's Avatar
Not anymore
Thank you. You're probably right about it. These PCM's are just re-programmed. That's all. If you want partial, or even total control, invest in something more accessible, like the CZ, or the e-manage. I'm not trying to sell these off; I just think it will be less of a burden for your bank account. Plus, it probably wouldn't work on the USDM anyway, like IZoomZoomI said.
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
JimmyBlack
273
Feb 10, 2020 10:23 PM
mdl0209
May 23, 2019 05:46 PM
stickmantijuana
Rotary Swaps
11
Sep 24, 2015 12:47 AM
stickmantijuana
Non-Rotary Swaps
Sep 19, 2015 03:15 PM
