Oil Consumption Survey
Old Aug 29, 2004 | 12:14 PM
Domer's Avatar
I recently purchased a 6-speed RX8. What is the typical experience with oil consumption out there? The sales guy said to check oil level at every fill up, but hasn't known anyone that every needed to top off the oil. So what is your experience?
Old Aug 29, 2004 | 12:18 PM
poolsidenaz's Avatar
I'm @ 6800mi with 2 oil changes. Never had to add oil but I do check every month just to be sure.
Old Aug 29, 2004 | 12:20 PM
HeelnToe's Avatar
I add a quart every 2,000 miles or so to keep it between the hi/lo marks.
You won't need to actually ADD oil at every other fillup - it's merely a good idea to check it that often.
Old Aug 29, 2004 | 07:29 PM
DOMINION's Avatar
I don't buy Kool-Aid
I check my oil every top off and never short a quart
Old Aug 29, 2004 | 08:14 PM
r8ped8's Avatar
I am using about 1 quart after 2000 miles it appears. I believe the distance from the low mark and the high mark on the oil dipstick equals 1.8 quarts if memory serves.
So after 2000 miles I was about 1/4 above the low mark after being at the high mark when I made note at delivery.
However I only have 3500 miles on my 8 now and have read threads where oil consumption improves as miles accumulate on vehicle?
my experiece so far.........
Gary
Old Aug 29, 2004 | 08:31 PM
StewC625's Avatar
Insanely Yellow
I'm at 1700 miles so far and the engine oil level is about half-way between the full and add lines on the stick. Planning to add a 1/2 quart to bring it back to full. I'm guessing less than a quart consumption between 3000 mile oil changes.
Old Aug 29, 2004 | 09:24 PM
takahashi's Avatar
Use 1 L of oil per 200km --- hang on that is on the track.
Hehe normal driving probably about 200ml per 1000km
Old Aug 29, 2004 | 09:42 PM
Atacdad's Avatar
I check every 1000 miles. I'm just a few 100's shy of 5000 miles and have used 1 3/4 quarts. I've never had it get below the low tick on the dipstick, but this last check (3 days ago...checking level and quality since I'm expecting to take it in for its first oil change at 5Kmiles) I was 1/8" (3 mils for the metric dudes) above the low tick. Put in a whole quart. I don't normally fill it to the high tick...just keep it between the two.
Old Aug 29, 2004 | 10:12 PM
loco4rx8's Avatar
BSG 75
I'm getting the free oil changes every 5000 miles. I've got a bit over 20,000 miles on my car. Last 5000 miles, I had to add 1 quart total. About a 1/2 qt every 2500 miles.
Old Aug 29, 2004 | 10:28 PM
beachdog's Avatar
Hard to say. Car was delivered new overfilled. Two oil changes at the dealer and overfilled both times. Probably won't know for sure until I change the oil myself.
Just added about three ounces after 1600 miles since the last overfill er oil change.
Old Aug 29, 2004 | 11:02 PM
TownDrunk's Avatar
I am a meat popcicle
I have about 11500 mi, I've added a total of around 3 quarts (in addition to regular oil changes).
Old Aug 29, 2004 | 11:09 PM
VikingDJ's Avatar
Music and Cars!!! :)
Yeah same here. Car came overfilled, then on first oil change it was same. I guess they are told to do that to compensate for the people that don't check their oil, of change it when required. I just changed my oil myself recently, and put exactly 4 quarts in it. I'll now get to see how much it loses, and I'll check it after the first 1k to see what I come up with.
Old Aug 30, 2004 | 06:42 AM
Abracadabra's Avatar
over filled also
I have about 700 miles on our car...it too came from the dealer very overfilled....it's only now that it is at the upper marker. I was suprised to see the oil so full after taking delivery. Are there any issues with over filling or is it just a result of adding the recomended amount of oil during a change? I do however plan to to my own changes after the first dealer change.
Old Aug 30, 2004 | 06:50 AM
ZASKAR-RX8's Avatar
MAD 4 RX-8
1L -> 4.000kms
Old Aug 30, 2004 | 09:57 AM
chambo's Avatar
1500 miles on my baby and she's already downed a quart (third of the way above the low line)
Old Aug 30, 2004 | 10:22 AM
NavyDood's Avatar
Who is this Navy guy?
6300 miles on the wifes 8. Never had to top off. When I change the oil, I have never filled it right up to the full mark either. I always leave it a smidge under. Just my preferance. Then again I changed the oil at 500 miles, 3500 miles, and will again at 7500 miles. After that I am going to change it every 5000 miles. At that point I may need to top it off. She doesn't drive it as hard as I would or as others do. So that contributes to a lower oil consumption for her.
Old Aug 30, 2004 | 11:15 AM
Optimus812's Avatar
Zoom! - Zoom!!
Just passed 2000 miles and added 1 full quart...
Old Aug 30, 2004 | 03:37 PM
ZOOOMO's Avatar
1 Qrt every 3K miles for last 8000 miles.
Old Aug 30, 2004 | 05:29 PM
MELRX8's Avatar
"RX-8 my stress reliever"
Smile Adding Oil
I added a quart at 3500 miles and 5/8 quart at 5500 miles.
Old Aug 30, 2004 | 09:43 PM
SilverDart's Avatar
Still above the add line when I changed the oil at 2,500 miles.
Old Aug 30, 2004 | 10:41 PM
mpt_yellowRX8's Avatar
I have 15000 miles on mine and I have added a total of 1.5 quarts. I'm getting my oil changed this week so it will be a long time till I need to worry about adding again. I'll be sure to check it just in case something loosens up though.
Old Aug 30, 2004 | 11:56 PM
Old Rotor's Avatar
I have over 13k and have never added any oil. I just have the oil and filter changed at the dealer. So its 2.5-3k between changes, works for me. It's my 7th rotary. The oil consumtion depends on how deep you keep your foot in it. Race it and you wont even get 1k before you need a quart. It takes real disipline to stop yourself from redlineing it all the time. The rotary is electric!
Old Aug 31, 2004 | 12:59 AM
The dealer is wrong. Check your oil every other fill up.
I use about a 1/4 of a quart every other fill up.
It's best to keep it topped off. Your oil is like a motorcycle. It has a tank that pumps the oil into the engine. It was designed to consume oil. It drops oil on to the points to prevent wear of the tips.
Old Aug 31, 2004 | 01:38 AM
ZASKAR-RX8's Avatar
MAD 4 RX-8
I see here very very low consumption...
Old Aug 31, 2004 | 07:20 AM
takahashi's Avatar
ZASKAR,
Do you wipe the dipstick before you read it? My friend said his engine never use oil but I take the dipstick out - it was full - but then I wipe it and put it back and pull it out to look again - it was below the L mark.
Also, you need to check oil in a warm engine.
I may sound like it is abnormal to see rotary on consuming oil but I think wheather the checking procedure is correct
