Drivability issues after topping off oil? :confused:
Old Aug 25, 2004 | 08:35 AM
reddragonmd's Avatar
Yesterday afternoon my car was running a tad rough. I had the oil changed last tue. at the dealership. So i figured the oil was a bit low. I checked when i got home, and low and behold it was a notch above the L line.
I bought a case of oil from the dealership, the mazda 5w20 oil the 8 uses, figured why not for 24$. So i opened one up, and put some in, checked level, put somemore in until it was 3/4 to the top line. Put the oil lid back on, and left for the girlfriends. I noticed alot of bogging in lower rpms, and not a smooth rev to redline anymore. it feels like the car is fighting me past 6K rpms. Whats going on?
How high should you fill the oil on the stick?
What could be going on?
Anyone else have this happen?
I have the M flash btw. thanks
Old Aug 25, 2004 | 08:43 AM
RX8_Buckeye's Avatar
'O' - 'H' !!! ...
That doesn't sound like an oil problem to me. It could be a burnt coil. I'm sure someone here will have a good idea of what it is.
Old Aug 25, 2004 | 08:55 AM
thanks, im hoping someone will chime in
Oh, and no lights were thrown.
Old Aug 25, 2004 | 10:22 AM
NoPistonsHere's Avatar
RevBeeper
Could be spark plugs, (think the manual says to change at 30000 miles) check manual on that though!!
could be bad Gas
hard to say
where did you fill up??
Old Aug 25, 2004 | 10:33 AM
The car has 6800 miles on it, so im no where near 30K
When i topped off the oil i had half a tank of the same gas in it. it was ammoco 93
I just filled up this AM with exxon 91, still feels the same. grr
Old Aug 25, 2004 | 12:15 PM
RevBeeper
I will call this rotary guy, and get you some info.
Old Aug 25, 2004 | 12:34 PM
thanks alot, i appriciate it.
This thing has so many little things wrong. This drivibility issue, and then the crazy sounds from the suspension, during low speed turning an going over bumps...
Old Aug 25, 2004 | 12:57 PM
RevBeeper
I didnt get a hold of James From Krazy RPM, but I talked to another Rotary head and he was saying it is possably timing, My advice is... The car is under Warranty have the dealership check it. I will call james again and see what he thinks. Here is the number to his shop if you want direct advice 760 949 4424
Old Aug 25, 2004 | 07:21 PM
RX8by's Avatar
I would take it in for sure. Almost a qt low after 1 week is too much. Low oil shouldn't cause the engine to run rough. You got another problem.
Old Aug 26, 2004 | 12:57 AM
does it matter that i drove about 400 miles in that one week?
Old Aug 26, 2004 | 09:09 AM
SpinninAgain!'s Avatar
reddragonmd, I can't help with your main problem, sorry, but you just wrote:
...then the crazy sounds from the suspension, during low speed turning an going over bumps...
There's a TSB for this. If you haven't had it done, check the TSB list stickied at the top of the Tech Forum.
Old Aug 26, 2004 | 03:03 PM
RevBeeper
I talked to James, he said if you were Driving on low oil for a while the Bearings (Engine injects oil in the Bearings) in the rotors are damaged, thats a warrenty issue since mazda did not refill the oil, They probably gonna have to replace the whole engine if thats the case.
Old Aug 26, 2004 | 09:01 PM
Racer X-8's Avatar
Coming thru in waves...
How about this - are you pushing the dipstick all the way into its tube? If not, maybe the level was correct to start with, now it's way-overfilled. ?!?
I know, it sounds farfetched, but hey...
Old Aug 26, 2004 | 09:20 PM
PoLaK's Avatar
Son what is your Alibi?
My guess is the coils, or your oil metering pump and or map is screwed.
Time for a new engine you lucky guy
Old Aug 27, 2004 | 12:45 PM
RevBeeper
Ya, check the 8 into the dealership and see what they say. We are all interested in seeing whats going on, and if it is time for a new engine. Wow, a whole new engine with no cost to you would be nice :D as long as you dont get to many hassles hopefully not though!!!!!!!!
WingleBeast
22
May 23, 2016 09:22 PM
uZu
Dec 30, 2015 12:35 PM
SupraG
Sep 21, 2015 12:09 AM
RotaryRider
Jul 20, 2015 07:05 AM
vssystemluba
Jul 19, 2015 04:16 PM
