Grinding in reverse ... should I bring it in ?
Old Aug 19, 2004 | 08:52 PM
titaniumgrey's Avatar
18 year old speed freak
Damn , I dunno whats up , my car started grinding in reverse sometimes , is it my driving or the car ? , let me explain it , usually in a parking lot, reversing out it grinds , it's weird .... like I put it in reverse and it bounces back out allitle and then it grinds ..... then I put it back in reverse cause I always get scared somethings gonna break from the noise and then go for reverse again and it works .... then when I am backed up and ready to go , going into first gear is REALLY HARD , I have to release the clutch in neutral and then press the clutch again and it finally is ok to go into first ... anyone know whats up with the car ? Pretty weird , I sometimes get a stiff stick from second to third gear too. This has been since I bought the car new. Also if I goto the dealer , should I take out my intake ?
Old Aug 19, 2004 | 08:56 PM
mysql101's Avatar
No, but you have to practice pushing DOWN on the shift then pulling it all the way towards you till it goes into reverse.
What you're describing sounds like you're going half way into 6th or reverse and grinding.
I've done it a few times.
Going into first isn't easy if your car is already moving.
Old Aug 19, 2004 | 08:57 PM
oh thanks man , I was scared for a second , thought I had a bad transmission :p
Old Aug 19, 2004 | 08:58 PM
zoom44's Avatar
watch your rpms when going into reverse. a little blip on the throttle as you are shifting can cause the rpms to rise enough to make it hard to get in to reverse. make sure you are at a dead stop AND idle rpm.
Old Aug 19, 2004 | 08:59 PM
brothervoodoo's Avatar
RainMan is Back
Don't think you should but you know how the dealers will try to blame anything that isn't stock. There's been old threads about tthrow out bearings and pressure bolts being loose on some transmissions... Take it in, have them check it out..
Old Aug 19, 2004 | 09:00 PM
zoom44's Avatar
also look at the bottom of this thread and read those thread on reverse noises and problems with reverse listed there.
Old Aug 19, 2004 | 09:36 PM
Air Force RX8's Avatar
Who Cares?
I think it hurts nothing to take it in and have it looked at, but it is a different story if something does go wrong and you do nothing. Take it in get her checked out and move on. If it turns out to be nothing then at least you will know for sure.
Old Aug 19, 2004 | 09:46 PM
thanks for the fast responses people , I guess I'll get it checked , time to pull out the K&N I guess before I bring it in
Old Aug 21, 2004 | 11:15 PM
Dookie_Rx-8's Avatar
FourOneMuthaFcuknFive
try completely going to reverse and see what happens
theblinkof
Oct 4, 2023 05:24 PM
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
