GTech Pro Competition model & e-manage
Old Jul 26, 2004 | 02:21 PM
Phoenix_Master's Avatar
Arrow GTech Pro Competition model & e-manage
Soo whats a GTech Pro Competition model and how can I e-manage??
Old Jul 26, 2004 | 04:06 PM
Omicron's Avatar
Dude. To answer those two questions would take about 2 pages of typing. Try reading and searching a bit.
But in brief: The GTech Pro is a 3 axis accelerometer that lets you approximate performance measurements based on relative movement of the car in X, Y, or Z planes and calculations based on weight. You can read all about it here.
The Greddy eManage is a device that plugs in (or "piggybacks") on your car's engine control computer (aka "ECU or PCM") and allows you to control some parameters, like air/fuel ratio and ignition advance. On the RX-8, the eManage is usually called a "CanZoomer" or "CanZoomer Stage 1.X" mod, because they adapted the special plugs to make it plug right into the RX-8's, and designed some custom a/f and ignition settings to give the '8 more power.
Old Jul 26, 2004 | 11:41 PM
RotorMotor04's Avatar
RX-8 "SE3P"
Well put
Old Jul 27, 2004 | 12:00 AM
mqandil's Avatar
Omicron is a very patient man. well done, and well put
Old Jul 27, 2004 | 05:51 AM
Thanks all.
Old Jul 29, 2004 | 12:46 AM
davefzr's Avatar
Isnt the Greddy E-Manage different from the Canzoomer unit? Why do you refer to the E-Mnagage as the Canzoomer unit?
Old Jul 29, 2004 | 01:33 AM
Omicron's Avatar
The CanZoomer unit is an eManage with two important additions: custom plugs so you can plug your ECU right into it, and custom a/f and ignition maps to make your car run better.
Old Jul 29, 2004 | 01:36 AM
davefzr's Avatar
Ohhh.. so really e-manage is an industry wide term.... so greddy has their emanage and canzoomer has his... correct?
Which do you think is better for tuning? Or are they all the same in the end.
All this stuff.... http://www.greddy.com/prod_e_manage.htm
I pm'd you too if you would be so kind to respond.
Old Jul 29, 2004 | 08:09 AM
Speed Racer's Avatar
Certified track junky!!!
No, the Canzoomer Stage 1 is a Greddy eManage board that has been repackaged in a generic aluminum box. It is also pre-wired and programed so that you can just plug it into the factory wiring harness. Maurice has just gone out of his way to try to make tuning our cars "plug and play". If you want to save a few bucks you can buy an eManage instead. Then you will have to spend the time to figure out the wiring and create your own fuel maps. For me, it made more sense to buy the Canzoomer so that I wouldn't have to waste my time with the wiring and base fuel maps.
Old Jul 29, 2004 | 10:28 AM
davefzr's Avatar
Shutup......... no way.......
I have been a member on this forum for a long time and have read through countless threads just as a lot of other members..
I dont ever remember reading that canzoomer took an emanage for his own use... Wow.. I guess there are threads that I even skipped over....
Thankx for the info.
Is that legal?? haha
Paracleet
Feb 2, 2016 08:25 PM
urbanvoodoo
Sep 30, 2015 12:41 AM
Jb4ker96
Sep 27, 2015 10:06 PM
Stubbs
Sep 27, 2015 04:06 PM
