Stiff Shifting Problem can be fixed
Old Jul 12, 2004 | 03:14 AM
BlackAero's Avatar
Guys,
I saw this part from R-Magic that will fix at the base of the shift stick, it seems to be able to correct the stiff shifting and the end result is a smooth shifting. Looks to me someone have to organise a group buy for this approx. 3000yen.
http://www.autov.net/ClubCarDetail.a...CarNoteID=9613
Old Jul 12, 2004 | 08:42 AM
UG_8's Avatar
I know EZ have contacts with R-Magic. If can get the part number can order through them. Was about to get the ECU from them, but need to have 2 week downtime because ECU need to send to Japan.
Old Aug 6, 2004 | 12:59 AM
BlackAero's Avatar
Mazdaspeed has just release a short shifter, I am sure this will solve the stiff shifting problem. Have been hunting for a short shifter awhile and finally. Here comes my next mod. Cheers.
http://www.mazda.co.jp/mazdaspeed/news/2004/07.html
Old Aug 6, 2004 | 09:17 AM
Neon's Avatar
Black Ace
I heard short shifter from Mazda is kinda expensive. (Mazda's is 20% shorter shift only and i heard the only change may actually be a shorter stick dats all....
I am in the the R-Magic one. Whos in?
EZ guys can help to find out and order?
Old Aug 6, 2004 | 11:32 AM
UG_8's Avatar
Will check with them tomorrow....
Old Aug 7, 2004 | 02:24 AM
Neon's Avatar
Black Ace
T Q.
If u can, also can help ask about the NGK original spark plugs $?
Also heat range 8 for leading pair if they can be ordered?
Old Aug 10, 2004 | 10:14 AM
Zo0oM's Avatar
The "stiffness" has gotten better on my RX8. It was quite bad when new, but has gradually improved to an acceptable level. It's just over the 1k mark now...and I hope it'll continue to improve. If anyone does get the MazdaSpeed or the R-Magic kit, I would definitely like to hear some feedback regarding whether there's any improvement.
Old Aug 10, 2004 | 11:48 AM
Neon's Avatar
Black Ace
UG any update?
Old Aug 10, 2004 | 09:53 PM
UG_8's Avatar
They still checking...
Old Aug 10, 2004 | 10:03 PM
M-ster's Avatar
Well, EZ is never easy to deal with
Old Aug 10, 2004 | 10:19 PM
UG_8's Avatar
Hi M-ster,
You can say that again.
Old Aug 10, 2004 | 10:27 PM
Gomez's Avatar
Shifty Bastard.
It's mounted higher on the shifter housing which changes the pivot geometry. You can see the white spacer that does this in the photo. I'd say it'd be the same length as the stock shifter.
Gomez.
Old Aug 11, 2004 | 10:33 PM
UG_8's Avatar
Hi All
For the R Magic part, the Japanese Techie person from EZ-import is on vacation, thus most likely will delay in response.
UG
Old Aug 12, 2004 | 08:23 PM
Neon's Avatar
Black Ace
Thanks for clarifying Gomez..
Old Aug 12, 2004 | 10:13 PM
Gomez's Avatar
Shifty Bastard.
No worries, Mate....
Old Aug 19, 2004 | 11:24 PM
UG_8's Avatar
Hi Guys,
The R-Magic part is $100 am also asking them how much is the labour for the change. So anyone interested?
UG
Old Aug 20, 2004 | 12:30 AM
M-ster's Avatar
$100 that's cheap!?
Old Aug 20, 2004 | 06:24 AM
Neon's Avatar
Black Ace
ok, i dun mind
Old Aug 20, 2004 | 11:23 AM
UG_8's Avatar
M-ster,
Daniel told me the part alone cost $100. So far, interested parties are:
1. UG
2. Neon
I will do so more checks with them. I will leave this group buy open till Monday night.
Old Aug 24, 2004 | 04:56 AM
UG_8's Avatar
M-ster,
1. UG
2. Neon
The total cost (Part + Installation) is $150. So I guess only Neon and myself will do it. Right?
Old Aug 24, 2004 | 08:10 AM
Neon's Avatar
Black Ace
ok :P
RevMeHarder
Jun 1, 2026 02:30 PM
DVerdeyen
Sep 13, 2015 11:19 AM
ed0128
Sep 9, 2015 04:50 PM
Kim Jong Illest
Sep 4, 2015 04:27 PM
