View Full Version : Would a highlfow Cat help reduce cabin heat?
brillo
07-10-2004, 06:28 PM
just wondering if the stock cat might be causing the heat build up as it doesn't flow well, would replacing it help?
brillo
07-11-2004, 06:41 PM
bump bump bump
Omicron
07-11-2004, 07:54 PM
Dunno. It's theoretically possible that they might, but only way to be sure would be to measure radiant heat with the stock cat, then compare that to the radiant hear of a high flow cat.
Maybe check with Maurice (CanZoomer), who is the only one I can think of that would have the capability to do this on separate cars simultaneously. Or maybe call Random Tech and see what they say... they might have measured this.
Another possibility is RX8Husker or Shebam, both of whom have HF cats + Borla exhausts. I'll have my HF cat back on the car next week, and I'll see if I notice a difference.
Hope this helps. At least it's better than no responses at all... ;)
dannobre
07-11-2004, 09:01 PM
Ive had mine on for about a week... I thnk that it is a little cooler
wakeech
07-11-2004, 09:56 PM
well the best way to reduce cabin heat would be to insulate it from the cat itself.
catalysts ain't cheap, so it may be cost effective to go with the extra insulation.
shebam
07-11-2004, 10:36 PM
I'd never thought about this, but entirely subjectively, I 'd say -- YEAH. We've had some hot patches and I do think the cabin has run a bit cooler this summer (perhaps the heat's been converted to noise :)). Of course, the engine bay, the PCM box, etc. are still broiling after running and take a super long time to cool down ....
