What gears are in the RX8?
Old Jul 7, 2004 | 06:57 PM
Tigster's Avatar
RX8 ADDICTED!!!
I was wondering what the gearing is in the rear end of the 8? Would this car not benefit from lets say 4:44 gears? Just so it can rev up faster, should shave some time off the quarter. I know it will raise the rpm's at cruising speeds and effect milage, but if I wanted good milage I would have bought a Hybrid.
Old Jul 7, 2004 | 07:33 PM
zoom44's Avatar
Re: What gears are in the RX8?
they are already 4:444
Diff - 4.444
1st - 3.760
2nd - 2.269
3rd - 1.539
4th - 1.187
5th - 1.000
6th - 0.843
3rd gear is different in japan
Old Jul 7, 2004 | 08:47 PM
pret's Avatar
AbsolutelyNothingHappenin
japan
what is the third gear ratio for j-spec? if you want to rev faster, reduce the rotational weight (lightened flywheel).
Old Jul 9, 2007 | 10:44 PM
nmarz77's Avatar
That's what I'm wondering now. From what I've researched, the car pulls pretty strong in first and second and falls off in 3rd compared to it's competitors like the 350z.
Old Jul 9, 2007 | 10:46 PM
peterisurhero's Avatar
peterisurhero
i heard the feed final gear helps the car pull much harder in 3rd.
Old Jul 10, 2007 | 12:23 AM
nmarz77's Avatar
Yeah my guess is it would definitely help the car zip through 1st and 2nd a lot quicker and definitely keep it pulling harder in 3rd.
Dokuji
Nov 1, 2016 02:51 PM
MolsonB
Aug 8, 2015 01:24 AM
Belalnabi
Jul 17, 2015 07:48 PM
