Radiator Upgrades?
Old Jul 1, 2004 | 07:20 PM
mdawgx24's Avatar
Radiator Upgrades?
Just curious...Anybody upgrade the radiator yet?
Old Jul 2, 2004 | 07:25 AM
shelleys_man_06's Avatar
Not anymore
What's wrong with the radiator that comes with the car?
Old Jul 2, 2004 | 02:47 PM
mikeb's Avatar
100% Italian
nothing is wrong with it
but people always upgrade
Old Jul 3, 2004 | 01:40 PM
ScudRunner's Avatar
On time, on target
Vivid Racing changed out their radiator for one from PWR Racing in Australia...but I don't think it's available to the public yet...
Old Jul 3, 2004 | 03:55 PM
mdawgx24's Avatar
I found that corksport.com is selling R Magic's radiator, but it's a little pricey at about $1k or so.
Old Jul 3, 2004 | 06:38 PM
adrian-1's Avatar
Ex- member.
There's a mazdaspeed version. Link here.
Old Jul 5, 2004 | 10:03 AM
Not anymore
I've seen just about every aftermarket radiator for this car (RE Amemiya, FEED, MS, etc.). Overall, they're all pretty much expensive, and not worth the trouble. Do radiators make more power? Since they're heat exchangers, maybe you'll increase the thermal efficiency by 0.03%. Didn't it used to be the norm to upgrade the radiator on the RX-7, especially the FD? I don't think the trend would follow here. First of all, there's no heat inducing turbochargers. Second, assuming you're not driving the mess out of your 8, if you're having cooling problems, I don't think an aftermarket radiator is a solution. Spend wisely .
Old Jul 8, 2004 | 06:08 PM
VividRacing.com's Avatar
Yes, I have the PWR radiator in my ride. It's one of the first things we do to our cars because of the extream heat we deal with here in the desert. It helps keep the engine coolant temps moderate on the 110+ degree days. So far no problems what so ever. They should be available to the public soon. For those of you planning to run some form of forced induction down the road, you may want to consider it as an upgrade as trubos and superchargers will raise the engine temps and rotaries are notorious for high engine temps anyway. Also, since the car sees track time I felt it was a must. Better safe than sorry.
Old Jul 8, 2004 | 06:22 PM
Not anymore
Are ideal radiators only supposed to lower the temperature of the coolant running through it? They're not suppose to drop the pressure, correct? What kind of radiator is the PWR? Is it a cross-flow or a down-flow? How many rows is it? Speaking of cooling systems, does anyone know the temperature at which the RX-8 thermostat opens?
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
olyrx7
Oct 26, 2015 09:23 AM
Quiggs321
Sep 30, 2015 05:34 PM
drlubell
Sep 26, 2015 11:58 PM
