Squeaking Clutch
Old Jun 29, 2004 | 10:02 PM
MacDude's Avatar
Squeaking Clutch
My clutch squeaks whenever I press it. Should I be worried about this? Is it probably just something that needs lubrication? Anyone else have this?
Old Jun 30, 2004 | 01:20 AM
EstonRX's Avatar
Can you tell where the squeek is coming from? Often it's just the pedal, and not anything to do with the clutch assembly, in which case it is nothing to worry about and a little greese should help. If it sounds deeper, like it's not coming from the pedal, then it's something that should be looked at for sure.
Either way, if you have a chance to stop by a dealer or are going to bring it in for any other reason some time soon, no reason not to bring it up then.
theblinkof
Oct 4, 2023 05:24 PM
XianUnix
Sep 29, 2015 03:48 PM
tommy26Germany
Sep 29, 2015 10:33 AM
GARCIAC951
Sep 10, 2015 07:17 PM
Kim Jong Illest
Sep 4, 2015 04:27 PM
