1st to 2nd...
Old Jun 29, 2004 | 09:06 PM
evilbada1's Avatar
1st to 2nd...
I'm having trouble shifting smoothly from 1st to 2nd gear..
I can shift somewhat smoothly when the rpm's over 4000.
but at lower rpms, I am kinda having problems shifting smoothly...
my friend who has a g35 drove my car and he shifted very smoothly at low rpms..
what should I do?
Old Jun 29, 2004 | 09:14 PM
G)(O's Avatar
WoW
you probably arent giving it enough gas... when you do shift at lower rpm's ease the clutch off a lil slower or just rev the car a lil higher
Old Jun 29, 2004 | 09:16 PM
mysql101's Avatar
you need to let off the clutch slowly.
Old Jun 29, 2004 | 09:45 PM
Chino075's Avatar
Try to give balance it out between gas and clutch, since ur in low rpms.
Old Jun 29, 2004 | 09:58 PM
zoomed's Avatar
You did not mention if you are new to manuals. You may need to find the engage point (where in the travel does the clutch actually engage) and sort of practice going through that. I would always suggest going by yourself and practicing different things
Old Jun 29, 2004 | 10:49 PM
VmanX's Avatar
hey.. same thing happens to me.. but it is probably becuz you haven't upgraded ur pcm to M flash yet.. if i remember correctly from a previous thread, the M flash upgrade also helps the unsmooth transition from 1st to 2nd gear.. i'm gonna get my upg this friday at the dealership and hopefully everything will be alright
Old Jun 30, 2004 | 08:32 AM
blue flash's Avatar
i learned if yyou dont keep the rpm's up it makes you feel like you are hitting the brakes alittle
Old Jun 30, 2004 | 06:33 PM
khoney's Avatar
FX8TED on my RX-8
Why would anyone shift from 1st to 2nd below 4K anyway? :D
Old Jun 30, 2004 | 10:05 PM
Brandon's Avatar
Don't take your foot off the gas right away after hitting the clutch, let it float a brief moment after you put the clutch in. Or just shift supa-fast, it doesn't seem to mind. :D
red_rx8_red_int's Avatar
Because if you want to obtain the stated mpg, you shift at 2k. And drive the speed limit on the highway. It is acheivable for me but not worth the effort.
Audio Concepts ATL
Sep 26, 2021 01:59 PM
wanted797
Aug 26, 2015 11:24 PM
GracefulShanks
Aug 18, 2015 11:40 AM
AussieGray
Jul 16, 2015 03:58 AM
steelerfan
RX-8 Multimedia/Photo Gallery
Jun 17, 2003 12:34 AM
