Idling
Old Jun 21, 2004 | 05:57 PM
Like Whoa's Avatar
Idling
Ok When i turn on my car and let it idle its pretty loud. I was wondering if this is normal or no? I got an automatic btw
Old Jun 21, 2004 | 06:07 PM
zoom44's Avatar
no i cant even hear my car at idle.
Old Jun 21, 2004 | 06:22 PM
ice8's Avatar
You need to get your hearing check.
Old Jun 21, 2004 | 08:07 PM
Phlash's Avatar
Go Speed Racer, Go!
be nice.......yes it's normal, when starting up cold the engine will start off at around 2500 rpm and should calm down to a tick under 1000 rpm in a couple minutes. The only thing that could make it seem a little louder is if you have the AC on.
Old Jun 21, 2004 | 08:31 PM
zoom44's Avatar
why? this car is not loud at idle. doors closed, windows up it should not be in the range where someone inside the car calls it "loud". add the radio on 5 or higher and you wont hear it idle.
p.s. check your spelling and/or grammar. "check" as you used it in your sentence should have been "checked"
Old Jun 21, 2004 | 09:46 PM
Haze's Avatar
Yeah, the idle can be kind of loud at start up, and that is normal because it is idling a little high and a little rough. It should be nice and quiet when the car is warm though. If it idles loudly all the time, you might have a problem.
Old Jun 22, 2004 | 11:50 AM
Like Whoa's Avatar
Ok thanks a lot. It only idles the first couple of minutes when i start the car. i guess that is normal. Thanks again
theblinkof
Oct 4, 2023 05:24 PM
Shankapotamus3
Mar 14, 2021 03:53 PM
Danield97
Sep 30, 2015 05:59 PM
Quiggs321
Sep 30, 2015 05:34 PM
