P5..fornow
03-11-2003, 01:01 PM
And gee I was going to post about torque:)
I read where the RX8 has a softer ride then the competion. But, it has the highest "Fun" factor. mmmm, sounds real familer. You know I now have a P5. It handes great, but some think it should handle a little better. So, they run off and put lower/stiffer springs on it. I have a feeling some RX8 owners will go down this same route. I have a problem with this approach. First, these cars already sit low and the suspensions is designed for this ride height. Second, by going to stiff springs you loose road/tire compliance. I have been doing the sports car thing for many, many years and found that fine tuning of the suspension is best done with shocks/sway bars. I try and tell the childern (not all of them, but a large percentage) on the P5 forums (every other word is "rule") this and get shot down. They are stuck in lowing a car and by doing so they are messing up the dynamics of the car. Stiffer lower springs are for cars that are not designed to handle well and you are starting from scratch - ie, a pickup, family sedan...
So, here are my thoughts (if you really need more:)). On the RX8, if you want less roll, is to increase the damping of the shocks for better road compliance, increase the sway bar dia. and use poly bushings. The RX8 is a great design and would be messed up by lowering. What do you think???
Oh yea, talked to the wife. Hope to place my order in a couple of months. Thinking silver/red.
One more thing - for the guys that are looking at a RX8 for a first car check out a P5 - cheaper (cost/insurance), looks "cool", and more forgiving at the limit (front drive - just plows itself to a stop if you mess up). And the thing is bullet proof.
You all have a great day!
