The Mystery of 'Octane' Finally Uncovered
Old Jun 18, 2004 | 03:46 AM
Hymee's Avatar
Race Steward
I just found this very interesting article. I think it somes up a few things that have been said on here in a few random threads.
I thought some of you might like to read it.
http://www.superchargersonline.com/content.asp?id=105
Take note of the paragraph "What's the benefit of higher octane?"
Cheers,
Hymee.
Old Jun 18, 2004 | 01:08 PM
downshift's Avatar
<p><
Is it true that some engines would continually advance the timing until it senses a knock? That way it will in some sense detect the higher octane and thus utilizes the most efficient timing for that level?
Old Jun 18, 2004 | 05:03 PM
Hymee's Avatar
Race Steward
That would depend on how the PCM is programmed. From my experience, they retard it from the pre-programmed value when knock is detected as a saftey measure, rather then the other way around for a perfromance measure.
Cheers,
Hymee.
Old Jun 19, 2004 | 02:07 AM
takahashi's Avatar
Great find... thanks Hymee.
I think fuel additive to increase Octane do nothing for Renesis.
But it does better for VTEC engines - I have knocking in 2nd gear 6500rpm unless I use BP or Optimax and fuel additives.
Old Jun 19, 2004 | 09:56 AM
ypwpat's Avatar
Sorry what the Hell is Knocking? :p
Is it something that sound like knocking on your engine?
I don't quiet understand.
Old Jun 19, 2004 | 06:26 PM
Hymee's Avatar
Race Steward
Did you read the link? There was a short explanation there, and a link to an more in-depth article.
Your mission, ypwpat, is to read the articles and provide us with a summary
Cheers,
Hymee.
Old Jun 19, 2004 | 07:56 PM
ypwpat's Avatar
ok is this right?
Knock/detonation is the Ignition of air/fuel Mixture before the spark plug ignite it due to high temperature on the engine?
Old Jun 19, 2004 | 08:42 PM
DMRH's Avatar
You have now discovered what Mazda & all other Wankel license holders found out back in the 60's..........
The compression process within a rotary engine is (obviously) different to a piston engine & as a result the Octane range is far larger than a piston.
I recall an engineering paper from Curtiss Wright (USA license holder) I read some years ago. Back in the early 70's they tested a 160hp 2-rotor NA engine (RC2-60=9.2:1 compression rotors). From a RON range of 85 right through to 103, the engine ran perfectly without any knock & recorded a variance of 4hp.
They noted in the paper that the jets from the carby required altering in the higher RON ranges. A piston engine with the same compression would ping & go bang........
I have mentioned this before, but the only difference you will find between normal ULP & Ultimate/Optimax is in the wallet.
Get a turbo happening & the compression increase changes the story when boost comes close to 1-bar.
Old Jun 20, 2004 | 02:23 AM
Hymee's Avatar
Race Steward
Originally posted by ypwpat
ok is this right?
You got it. Basically it is an explosion (rather than a burn) before iginition is intended, and puts all sorts of undesirable stresses on things.
Cheers,
Hymee.
RevMeHarder
Jun 1, 2026 02:30 PM
dezau
RX-8 Racing
10
Mar 9, 2016 09:50 AM
Racingjunkie
Sep 29, 2015 05:05 PM
pjwermuth
Sep 28, 2015 11:36 PM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
