Foud the perfect off the shelf subwoofer enclosure!!
Old Jun 17, 2004 | 07:09 AM
Wurmfist's Avatar
FEAST!
I just wanted to let everyone know that there is a 10inch x2 subwoofer box made by Q-Logic and is sold at Best Buy that fits perfectly into the space behind your seats in the trunk. There's even room for your fix a flat kit to stay mounted to the side. It looks like it was custom made for my RX-8.
Old Jun 17, 2004 | 08:36 AM
RX8-Raider's Avatar
Which one of these is the one you got?
http://www.qlogic.ws/2003/products/q...jsp?classID=55
Old Jun 17, 2004 | 04:50 PM
EatMyBanana's Avatar
I also would like to know which one ? thanks
Old Jun 17, 2004 | 07:35 PM
Wurmfist's Avatar
FEAST!
The model number is QLH-10D65, although I didn't see it on the website, it's the 10" Dual Chamber
Old Jun 17, 2004 | 07:59 PM
o0o0o's Avatar
Here it is on BestBuy's site:
http://www.bestbuy.com/site/olspage....2&type=product
Can't tell much from the picture though.
Old Jun 17, 2004 | 09:14 PM
Wurmfist's Avatar
FEAST!
Yep, that's the one, it's a really good fit!
Old Jun 18, 2004 | 12:12 AM
Thanks for the info .
Old Jun 18, 2004 | 01:13 PM
enmiiknee2mk's Avatar
i had mine cutom made to fit my 2 perfects exactly in that little slot
Old Jun 18, 2004 | 01:19 PM
stauburn's Avatar
Do you have a pic of it in your ride?
Old Jun 18, 2004 | 06:14 PM
Wurmfist's Avatar
FEAST!
I just now finished it up, I'll be sure to post a pic as soon as I get back outside.
Old Jun 19, 2004 | 09:08 AM
Wurmfist's Avatar
FEAST!
Well, here it is. When mounting the amp to the box you have to put the box in first and then mount the amp, otherwise it won't fit through the opening. I'm very happy with the install, but my speakers inside the cabin seem distorted now so it looks like I have some wire traceing to do.
Old Jun 19, 2004 | 09:14 AM
Wurmfist's Avatar
FEAST!
Here's a pic of how I secured it inside the trunk. I used two eye hooks and some high strength zip ties around the holes in the upper frame. You can only see the hooks if you stick your head inside the trunk so it works out well.
Old Jun 19, 2004 | 06:09 PM
adrian-1's Avatar
Ex- member.
It would sound better if they were "rear firing" like the box in the best buy link. That box does fit perfectly. I test fitted it in my 8, before buying the JL Audio enclosure with subs that had the same dimensions.
Here's my JL enclosure with 2 10 w6v2's.
Old Jun 19, 2004 | 09:14 PM
Wurmfist's Avatar
FEAST!
well one day when I have the energy I will spin the box around and see how it sounds. I got the distortion fixed and the bass sounds good, it's not ground shaking by any means, but it's still good, which was what I was going for.
Old Jul 2, 2004 | 05:43 PM
bean438's Avatar
So what was the distortion problem, and how did you fix it?
It would be nice to know in case one of us expierences the same problem.
Old Jul 2, 2004 | 09:01 PM
phillip's Avatar
Subzero ABS102
I bought the Subzero ABS102 and installed a pair of Adire Brahma Mark II drivers. It it driven by a pair of Lunar L2200 amps.
Dual 10" sealed
0.50 ft3 x 2
30.00" wide
13.00" high
8.30" top depth
11.80" x bottom depth
http://www.subzeromfg.com/aseries.htm
http://www.adireaudio.com/StockProducts/raw_drivers.htm
http://www.lunaramplifiers.com
Old Jul 2, 2004 | 11:10 PM
Wurmfist's Avatar
FEAST!
I'm not really sure what was exactly causing the distortion problem but I was using the pre-amp inputs into the Bose amp to feed my Kenwood amp, and since it was on mono and only uses the left channel I disconnected the right pre-amp and the distortion went away. So the only thing I can figure is that the instructions where wrong on the colors for the preamps and I was using the wrong ones on the right channel. Not sure though, all I know is that it sounds great now.
Old Jul 3, 2004 | 01:53 AM
mlino01's Avatar
rear firing
these JL s fit well and are rear firing.
theblinkof
Oct 4, 2023 05:24 PM
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
Learners_Permit
Sep 27, 2015 07:38 PM
GK1707
Sep 27, 2015 07:33 PM
