I have a pic I want to change into an avatar, can someone help?
Old Jun 16, 2004 | 06:16 PM
WinBlue06's Avatar
I have a picture on my computer that I want to change into an avatar, and I used Photoshop to change the size to 100x100 but when I try to upload it, it says "this picture is too big, the maximum size is 6120 bytes". Can someone help? Any help is appreciated, thank you.
Old Jun 16, 2004 | 07:09 PM
Tamas's Avatar
Registered Lunatic
Try to decrease the number of colors... often, 65K colors are sufficient instead of 'true color' and the picture will still look fine.
Old Jun 16, 2004 | 07:17 PM
bwayout's Avatar
Try making the height smaller at 75 pixels, leaving the width alown at 100 pixels. (That's the size I ended up using for mine)
Plus make sure your at 72 dpi (resolution), than, in Photoshop change your setteing under IMAGE (at the top menu bar) - pull down to MODE, than select INDEXED COLOR and save it as a GIF (uses less colors which will make it a smaller file than a JPEG – but it won't look as nice as a JPEG, but who cares ... it's only a small avatar)
That should help you!
Good luck!
Old Jun 18, 2004 | 05:01 PM
bwayout's Avatar
... I was wondering how you were coming along with your avatar?
Also, WinBlue06 if you don't know how to get less colors... try this:
In Photoshop when you choose "Save for web" (found under FILE at the top menu bar) than just above the image preview screen, choose 2-up – that way you can see your original and also see what the optimized version will look like (at the bottom it will also show you the file sizes too) – then select the setting (on the right side) GIF instead of JPEG, and "diffusion" and make sure that "interlaced" is NOT checked. Try experimenting with less colors – you can see the difference. when you like wat you see click save in the top right and that should be it!
Old Jun 21, 2004 | 02:11 PM
WinBlue06's Avatar
Thank you so much!!
Old Jun 21, 2004 | 07:12 PM
bwayout's Avatar
WinBlue06, your avatar came out very nice.
I like the golden lighting and the shadows on your z.
I guess we have a couple of more years to see your winning blue RX-8...
Old Jun 21, 2004 | 09:20 PM
Detroit RX8's Avatar
You can also reduce the quality when you save the jpg in Photoshop wich saves a decent amount of size and IMO doesn't mess up the pic too much (at least at 100x100).
Old Jun 22, 2004 | 07:40 PM
BaronVonBigmeat's Avatar
Senor Carnegrande
If you have a picture that you want to get just baaarely under a certain file size limit, the best thing to do is File-->Save For Web. You get a preview screen with all sorts of options for tweaking an image size.
JimmyBlack
273
Feb 10, 2020 10:23 PM
tallestmexican
May 1, 2018 07:22 AM
Trancemission
RX-8 Multimedia/Photo Gallery
46
Dec 2, 2015 07:26 PM
TJSiegrist
Sep 10, 2015 09:29 AM
iwannarun
Sep 6, 2015 01:37 PM
