View Poll Results: The best place for your XM unit?
tray/cig. adapter
57.14%
Above glove box
0%
ceiling in front of moonroof
14.29%
left side of steering wheel
0%
Other location (plz specify)
14.29%
In overhead sunglass holder
14.29%
Voters: 7. You may not vote on this poll
Where do you put your XM?
Old Jun 14, 2004 | 03:16 PM
DateAn8's Avatar
The best place to mount your XM radio unit in the 8?
Old Jun 14, 2004 | 03:21 PM
Shooter's Avatar
I have the SkyFI and had it put in the glovebox. Looking to put is someplace else but havent had the time to do a custom install.
Old Jun 14, 2004 | 03:22 PM
DateAn8's Avatar
Were you able to get it to work with the FM Modulator?
Old Jun 14, 2004 | 03:37 PM
Shooter's Avatar
yes although i had big time reception troubles. I would get alot of static. I switched the frequency and now it seems to work fairly well. Still waiting for an aux in to the radio to be built. the sound quality of an fm modulator is not good in general.
Old Jun 14, 2004 | 04:06 PM
zzum-zum's Avatar
I put mine in the cupholder. These pics are not of my car, I got the idea from them. Do a search on xmradio (no spaces) to read the thread.
Old Jun 14, 2004 | 04:08 PM
zzum-zum's Avatar
It's not too inconvenient to get to, but you have to look down to see info.
Old Jun 14, 2004 | 04:13 PM
DateAn8's Avatar
So do you use the FM mod. like they are talking about in that linked thread? If so, how does it work?
Old Jun 14, 2004 | 04:30 PM
zzum-zum's Avatar
You have to use the modulator unless you have a cassette deck. It taps into the car's antenna cable. The guy who installed mine said he found a connection up under the dash on the driver's side. I've seen some threads where people have said you need to pull the head unit to get to the antenna.
Old Jun 14, 2004 | 04:32 PM
DateAn8's Avatar
When I said "how" I meant is it static or clear? Any problems?
Old Jun 14, 2004 | 07:31 PM
bigfatpop's Avatar
I have the Roadie, and mounted it on my dash, just behind the washer/wiper stick. Ran the wires out the back, under the steering wheel column, and hard-wired it to the fuse box. I tried the FM modulator, but the sound quality, and lack of bass was not acceptable to me. Instead, I used the casette adapter that came with it. The sound quality is excellent, but I have a single wire coming from the tape deck that I wish was not there. It's not all that noticible, but I prefer it over the FM modulator.
Old Jun 14, 2004 | 08:38 PM
InuYasha's Avatar
Ask me! I might...
I put mine in the cup holder. Its hard to read the display while your driving, but its easy to hide, just slide the cover closed.
https://www.rx8club.com/showthread.p...5&pagenumber=1
Old Jun 14, 2004 | 08:44 PM
InuYasha's Avatar
Ask me! I might...
I use the combination power adapter+FM modulater. I have it plugged into the power port in the rear center console, next to the dvd unit.
No need to take apart the radio head unit or complicated wiring. It sounds good, but it i think it would sound better through an aux in. The bass and treble levels have to be readjusted when listening to the xm unit for the best sound.
Old Jun 14, 2004 | 09:48 PM
zzum-zum's Avatar
Sorry
I have the antenna mounted on the rear deck and have great reception and no interference problems at all. All the highs and lows sound fine too.
Old Jun 22, 2004 | 11:05 AM
DateAn8's Avatar
I finally got my Delphi installed. Had it custom done because I wanted it mounted on the ceiling between the light console and sunroof. Awesome place so the passenger can see the song and artist without looking down and back and I still have my cupholders and it's not in the way. They did a good job but charged $100. They also had to mount the antenna on the trunk lid because it couldn't shoot a clear signal through the back windshield. The only negative is they drilled holes where they mounted it, but it's ok because I'm not getting rid of my 8!
Old Jun 22, 2004 | 11:59 AM
InuYasha's Avatar
Ask me! I might...
How about a pic of the install. I'm curious to see what that looks like. I've temporarily put mine in the cup holder, but it makes it difficult to read. I'm looking for a better location.
Old Jun 22, 2004 | 12:00 PM
DateAn8's Avatar
Sure, give me 24 hours
Old Jun 22, 2004 | 08:02 PM
DateAn8's Avatar
Cam isn't the best but this is the install on the ceiling. It looks off centered a little but that's because I'm sitting off centered cause of the cool console in the back.
Old Jun 22, 2004 | 08:07 PM
DateAn8's Avatar
XM radio in ceiling
Old Jun 22, 2004 | 08:13 PM
DateAn8's Avatar
pic 2
Old Jun 23, 2004 | 12:12 AM
colin204's Avatar
custom mount
Old Jun 23, 2004 | 07:20 AM
DateAn8's Avatar
That looks like a custom picture
Old Jul 1, 2004 | 04:40 PM
Boozehound's Avatar
Get Hooked
Anyone mount the Roady in the ash tray?
cliffkemp
Dec 24, 2024 10:48 AM
tjohnmeyer
Sep 28, 2017 05:03 PM
Michael Bryant
Oct 12, 2015 03:07 PM
Eliseo Esquivel
Sep 30, 2015 08:28 PM
Quiggs321
Sep 30, 2015 05:34 PM
