Renesis Rotors
Old Mar 8, 2003 | 12:35 PM
N20SA22C's Avatar
Question Renesis Rotors
Why is it that for the last 1-2 years Mazda Kept showing us pics of a Honeycomb type structure for the rotor. They plastered it everywhere and now are using a stainless steel rotor that is more similar to the original design? Not to say the original design was bad but did they encounter problems with the new one? Any insight would be appreciated.
Kyle Lancaster--Double Agent Salesman
Old Mar 8, 2003 | 01:59 PM
zoom44's Avatar
this was covered elsewhere on this forum awhile age but to save you some searching-the gist of it is that those honeycomb rotors that you speak of and the ones they show now are the same ones.the honeycomb ones are actually cutaways of the regular rotors so you are looking at the inside and not the outside face :D
Old Mar 8, 2003 | 02:10 PM
amgtortoise's Avatar
The honeycomb cut-away rotors were indeed Stainless steel rotors! Japan/USA Mazda develop the use of new material for multi-rotor engines in late '80s to reduce weight & friction by use ceramics seals (guru designer Dr. Iannetti & engineer Rick Engleman). It's nothing new, but it's new to the consumer public. I'm glad to see Rotary racing technologies are being past to the consumer after a decade of R&D.
Kenichi Yamamoto & Rick Engleman are considered the GODs in the entire world of rotary engine.
Old Mar 8, 2003 | 02:23 PM
wakeech's Avatar
mostly harmless
the rotors have always been hollow: they have to be so the e-shaft can spray oil all over the insides to cool it. seriously, they've always been hollow cast, and yeah, they're just cutaways
Old Mar 8, 2003 | 10:12 PM
N20SA22C's Avatar
Very helpfull, I have been around RX7's since I was three and drag a 1st gen and didn't know those were cutouts. I knew they were not solid but didn't put it together. Thanks again.
Old Mar 9, 2003 | 09:49 AM
wakeech's Avatar
mostly harmless
... those 1st gen rotor don't FEEL like they're hollow, do they ??
Old Mar 9, 2003 | 11:15 AM
N20SA22C's Avatar
I have a Rotor and housing in my office and it is quite heavy, Do you know the weight of the new Stainless rotors? They are beautifull. The old ones were over 9 lbs correct? thanks
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
jamespond24
Dec 1, 2015 11:11 PM
TotalAutoPerformance
Vendor Classifieds
Oct 14, 2015 12:29 PM
Eliseo Esquivel
Sep 30, 2015 08:28 PM
pjwermuth
Sep 28, 2015 11:36 PM
