1 Thumb up 1 down.
Old Jun 10, 2004 | 12:06 PM
The_Bean's Avatar
1 Thumb up 1 down.
Thumbs up to the Canzoomer unit. Installed it last night and I can immediately feel more pull especially in the high end.
Thumbs down to the Random tech mid-pipe w/ resonator and high flow cat. Makes it too loud and did not come with all the necessary bolts.
Also, the engine idle does seem to be rougher—RPM’s seem lower. From discussions the CZ unit is not doing anything at idle. Could it be to the ecu re-learning?
Anyway I would defiantly recommend the unit to interested buyers.
I would not use the mid-pipe w/ after market cat back—in fact I think I’ll put stock back on like Canzoomer did.
Cheers,
Ben
Old Jun 10, 2004 | 12:35 PM
Omicron's Avatar
Canzoomer put the stock exhaust back on, not the stock cat. I was the one who did the latter, and just temporarilly until I can work out an additional muffling solution.
Old Jun 10, 2004 | 12:38 PM
cgrx's Avatar
DRIVEN
so the resonator doesn't do much to quiet it ?
Old Jun 10, 2004 | 03:15 PM
The_Bean's Avatar
I'm going to put the stock exhaust back on--not cat
Old Jun 10, 2004 | 04:58 PM
adrian-1's Avatar
Ex- member.
I''m sure the resonator does muffle the sound some. I've read the sound without the resonator is unbelievably loud.
Old Jun 10, 2004 | 10:09 PM
RX-8 friend's Avatar
Correct. If you have a cat back without the resonator, you will not like it. It's still loud with the resonator and a cat back, but not deafaning. Maurice put the stock muffler (cat back) back on and it's very quiet.
Once again, the high-flow cat is not there to increase HP (it -may- add a few or it -may- take away a few). It's there for Stage 2 so you don't melt the stock cat. It can handle higher temps than the stock cat.
Old Jun 20, 2004 | 12:09 AM
Twin 8s!'s Avatar
CZ Installed today
Got system installed with no major issues.
Took the car out for a 0-60 run and was impressed with the increase in HP.
More after some additional testing.
Old Jun 20, 2004 | 03:37 PM
diegodog's Avatar
What types of bolts are needed? My midp4 is on the way and I would like to have the bolts on hand when the unit arrives.
Did you need anything other than the bolts?
Thanks?
LB2739
Jul 9, 2019 02:25 AM
Sakebomb Garage
Sakebomb Garage
Oct 22, 2015 04:28 PM
Danield97
Sep 30, 2015 05:59 PM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
carid
Vendor Classifieds
Sep 10, 2015 09:26 AM
