j1mb0x99
06-08-2004, 08:01 PM
I just finished watching Tuner Transformations on SPEED channel. The show just redeemed itself after their abomination of the RX-8.
On it they took a Subaru STI and did to it exactly what I would like to do if I owned one.
Retuned the ECU.
New Intercooler.
Added intake.
Added Exhaust.
Installed a rear swaybar.
Upgraded brakes.
Then they painted the stock rims black and swapped a base model hood and trunk lid with the regular STI's.
Total sleeper car.
Just thought I would share and if this is a repost I appologize.
-JiM
Retuned the ECU.
New Intercooler.
Added intake.
Added Exhaust.
Upgraded brakes.
Total sleeper car.
-JiM
Upgraded brakes??? It comes with Brembos, I'm guessing you mean stuff like SS lines, motul fluid etc.
I can't believe they painted thise beautiful BBS wheels, I hope they got it professionally done and it was a black car.
There are a couple black FMICs available for the WRX/STi as well, and it looks really mean. Did they use the black?
wrx2rx8
06-09-2004, 01:26 AM
When is this show on? I missed both the rx8 and sti episodes.Saw the weak auto m3 episode.
I dont know if mine was an Sti i think id leave as so. Sleeper would be 02 03 wrx no sti available over here in that body style.
With the car being out longer /more parts it is fairly easy to make faster than the Sti.
The sleeper i want is a miata with 5.0 swap:D
DragonStar4681
06-09-2004, 10:32 AM
unfortunatly the car was silver. :( it didnt look that bad when it was done though.
liqiud
06-09-2004, 11:39 AM
i thought it looked good...unfortunately i missed the rx-8 episode, but i try to watch it as much as possible.
Kel Rx8
06-09-2004, 11:38 PM
havent seen it
this weeks show ?
aint nothing sleeper about a subaru sti
RX8-TX
06-10-2004, 10:16 AM
[i]aint nothing sleeper about a subaru sti [/B]
Except that it no longer looked like one.
Farsyde
06-10-2004, 11:29 AM
I think they took the cahones out of the car. Why spend 30k on a car your buying for only one reason, then strip it down to look like a 7k cheaper car. I'll admit the upgrades were nice, but still. They kept the old calipers and put in SS lines and cross-drilled discs. However, I think that they are gonna run into problems with the new exhaust. The STI boards are flooded with posts about boost-creep issues with any more freely-flowing exhaust is pu on. Since I didn't see any external wastegate or porting the original internal one and not to mention they uped the boost and retuned the computer, I think there may be some future damage to the engine there. All in all though still fun to watch.
wrx2rx8
06-10-2004, 09:34 PM
You retune the comp.Cause of the upped boost, to avoid engine problems.Anytime you mod a car/or drive it hard its gonna have future problems you just tune it right . Put that future as far out there as you can.
Farsyde
06-11-2004, 11:01 AM
Normally correct, but in the STI's case, wrong. The internal wastegate flange is too small to flow more than the stock boost. For some reason putting a free flowing exhaust on the thing, even without upping the boost, tend to boost-creep. There is NO tuning that can solve this problem as it is a mechanical issue that can only be resolved by porting the wastgate or replacing the system completely with a new turbo and external wastegate.
