Whine at High RPM
Old Jun 1, 2004 | 06:39 PM
legokcen's Avatar
The Turkish Delight
Whine at High RPM
Got a quick question.
I'm getting a bit of a whine (not the redline buzzer) or a different kind of higher pitched hissing sound from 7200 to redline. I've got a K&N dropin intake, and am running regular fuel. Could it be the last portion of the S-DAIS kicking in and making that sound?
By the way, what does pinging/predetonation sound like?
Thanks a lot!
Old Jun 1, 2004 | 07:09 PM
Rotarian_SC's Avatar
Free Autographed Pictures
I have only noticed some sort of hiss that happens sometimes if I accelerate. I determined that it stops if I have the fan off, and only noticed it at high rpm. I think the type of whine you are talking about is S-DAIS related because there is a high pitched whine near 3750rpms that I can hear to judge if I am going above or below 73mph without looking at the speedo or tach.
Old Jun 2, 2004 | 06:53 AM
rot8ryx's Avatar
I have noticed a whistling noise at higher rpms..... dunno if that would be a whine but it is getting me worried..... only mod i have is exhaust....
Old Jun 2, 2004 | 09:51 AM
mooneycj's Avatar
I think this is air sucking thru the intake you are hearing.
mooneycj
Old Jun 3, 2004 | 02:29 AM
wakeech's Avatar
mostly harmless
you're not going to hear much pinging on this engine as there are knock sensors which will do all possible to eliminate it when it occurs. sounds (apparently) like popping popcorn, but loud. and then your engine dies. so no, a hesitation or stagger is not from detonation, more probably a misfire or stuck intake system valve.
Old Jun 3, 2004 | 07:19 PM
Tony Orlando's Avatar
Bored thread resuscitator
I'd imagine you are hearing the same noise being discussed HERE
Some call it a "rattle", others a "whine", some a "ringing", while I'd describe it as a joy-buzzer type sound. (No, it's not the shift warning buzzer ) Nobody seems to be able to nail it down, but I'd say due to the number of people hearing it, it's the sound of the sequential intake opening valves.
WranglerFan
May 31, 2022 07:51 AM
JimmyBlack
273
Feb 10, 2020 10:23 PM
WranglerFan
Nov 5, 2017 09:35 AM
Hiroshima_RX
Sep 21, 2015 06:28 PM
Forevermore
Sep 20, 2015 01:04 PM
