racing hart... offset?
Old May 27, 2004 | 10:45 PM
jaehyun127's Avatar
Hi, i'm not to familiar with this. The famous rx-8 picture with the mazdaspeed kit and the racing hart 19" cx rims... What are the specs of that wheel? What offset?
ALso, the smaller the offset, the wider the rim? Is that correct? What does it mean when the offset number decreases? What is the offset of the stock oem 18" rim?
Thank you for your help people!
Old May 28, 2004 | 12:49 AM
Napboy's Avatar
Sho'Nuff
the offset on the stock wheels is 50mm. that means that looking at the rim from above, the center hub is 50mm (towards the outer part of the wheel) from dead center. so the smaller the offset, the more the wheel will "stick out."
i'm not sure what the offset is on the racing harts, but i would guess in the 40mm range in the rear.
Old May 28, 2004 | 11:24 AM
Kel Rx8's Avatar
if your not 1st your last
19x8.5 front
19.x10 rear
38 offset
44 offset
dont know tires though
Old May 29, 2004 | 08:04 AM
WTF no turbo's Avatar
Arent they toyo proxy4s?
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
hufflepuff
May 30, 2016 10:45 AM
RAVSPEC
Vendor Classifieds
Oct 1, 2015 01:59 PM
