rx8kid77
05-22-2004, 09:55 AM
Has any one ever taken their restricter plate off the intake of an automatic RX-8. Iam interested in doing this if anyone has any advice please let me know.
View Full Version : Restricter Plate help rx8kid77 05-22-2004, 09:55 AM Has any one ever taken their restricter plate off the intake of an automatic RX-8. Iam interested in doing this if anyone has any advice please let me know. w2aew 05-22-2004, 11:20 AM If you are referring to changing your 4-port engine into a 6-port engine on the auto - I would think that if you could do this, it probably wouldn't run right. The PCM is programmed to optimize the timing, injector profile, etc., for the 4 port design. Simply opening up the additional ports will screw this up. ...And to answer your next question, it probably is unlikely that the PCM could be reprogrammed to the 6-speed, 6-port configuration - because it "knows" that the automatic is there. Omicron 05-22-2004, 11:35 AM The PCM (ECU) would require complete reprogramming. As w2aew says, simply removing the "restrictor plate" would likely screw things up. Even if you could get it to work, the AT is not designed to handle the higher revs/HP/torque of the 6 port engine. zoom44 05-22-2004, 12:50 PM i think mikeb took his restrictor plate off. dcfc3s 05-22-2004, 07:20 PM There is no restrictor plate. The cast iron housings in the motor are totally different - the autos have 4 intake ports, the manuals 6. This isn't something you just unbolt and have free horsepower. Dale zoom44 05-22-2004, 08:01 PM are you sure? i think we need to ask mikeb about this. kristopher_d 05-22-2004, 11:30 PM Different rotor housings folks. mikeb 05-23-2004, 04:10 AM restricator plate? The only thing I removed was the plastic housing that sits under the intake when I got the K&N but I have now put it back on BoxerGT2.5 05-24-2004, 10:35 AM What are we NASCAR. Sorry had to....you say restrictor plate and the first thing that pops in my head is rednecks running around in a circle. But, Seriously......restrictor plates from what I recollect are typically found inbetween a carb and the block...(we don't have) or behind the TB. I don't believe I say evidence of one? Correct me if I'm wrong....which is quite frequent these days. :) |
