Power- and ground wire question
Old May 20, 2004 | 03:26 PM
Tamas's Avatar
Registered Lunatic
Question Power- and ground wire question
I need some help here.
I'm planning to install a subwoofer with it's own amp and an MP3 player in the trunk. The question is: is it OK to run one power wire from the battery and one ground wire to feed both components? Or do I need separate power- and ground wires for each component? Will I not end up with some ground loop or other problem when using just one set of wires?
If one wire is OK (certainly much easier), then how do I calculate the size of the in-line fuse I'll need?
I'm pretty green in this area...
Thanks.
Old May 20, 2004 | 11:03 PM
BoxerGT2.5's Avatar
You can use a distribution block and run 1 4 gauge power from the batt to the block. You can then run up to 4 separate 8 gauge power wires from the distribution block to the components you see fit. Each one should have there own ground.
Old May 21, 2004 | 03:30 PM
adrian-1's Avatar
Ex- member.
Circuit city should carry them. My distribution block is a rockford fosgate 1into4. Only using 2, one for the amp, the other for the cap.
adrian-1's Avatar
Ex- member.
amp and cap
drebbrnator
Dec 27, 2018 07:02 PM
stickmantijuana
10
Oct 27, 2015 04:11 PM
MolecularConcept
Aug 5, 2015 04:43 PM
Stubbs
Jul 28, 2015 09:23 PM
