Balky Sunroof Switches?
Old May 19, 2004 | 07:56 AM
Carolina8's Avatar
Wa Shing Ka
Anyone else having problems with the sunroof switches? I've had the car for about 7 months (10k miles). Up until the last month or so, a light touch on either switch (tilt or slide) worked. Now, I have to practically push the switch up through the roof, and it still may take several attempts to make it work.
Had the stealer look at it while the car was in for some other stuff. Got the usual "Unable to replicate customer complaint." It was too late in the day to argue with them, so I'll have to take it back again, as the problem continues.
Just curious if anyone else had the problem and what the fix was.
Old May 19, 2004 | 09:52 AM
Meowloud's Avatar
Short Bus Allstar!
Maybe no one is answering because they don't have the problem? Personally, I believe there is a problem if you have to depress that hard.
Is it every time you operate the moonroof?
Old May 19, 2004 | 09:57 AM
Carolina8's Avatar
Wa Shing Ka
Thanks... I did a search first, and came up dry, so I really didn't expect that this would be a common issue. The problem is intermittent, but happens more than not. My guess is loose wiring or a plug that's not seated properly. Either that or the switch unit itself is faulty.
Either way, I'm going to try to get it back by the stealer today or tomorrow to have the problem "properly replicated." Don't know why they couldn't take my word for it the first time. Would have saved me the aggravation of a second trip.
Old May 19, 2004 | 10:05 AM
Meowloud's Avatar
Short Bus Allstar!
If all else fails, take your recorder (or digital cam) and film/stream yourself in the car opening and closing the top. Take your camera with you to the dealer with it edited to a 'difficult switch' occurrence. Show them that and tell them FIX IT :D
Old May 19, 2004 | 10:44 AM
jonny's Avatar
hmm...well I don't have a sunroof on my RX8--but my Millenia S that I am tryin to sell experiences that sometimes--but it is a 1999 with 67000 so all I can say is take it to the dealer.
Old May 19, 2004 | 04:10 PM
stangmatt66's Avatar
North County Boi
no problems with my buttons...i just wish Mazda could have made the two switches into one nice rotary switch like VWs and Audi...too slick!
Old May 19, 2004 | 05:56 PM
Air Force RX8's Avatar
Who Cares?
No problems with the switches.
Old May 19, 2004 | 06:09 PM
NomisR's Avatar
Only problem I found with the switch is that they're too far back making it hard to find and use them when needed. However, they're really fast for moonroofs, one of the fastest I've used.
Old May 20, 2004 | 07:12 AM
Carolina8's Avatar
Wa Shing Ka
Sounds like mine's just busted, as we say here in the South.
I'll get it fixed. Thanks for all the responses!
Old May 20, 2004 | 04:43 PM
bluesunlion's Avatar
my other car is blue
Sounds silly, but check your fuses. I once had a random radio problem on another car, and there was a barely visible burn through on a fuse that would generally complete the circuit, but not always.
cliffkemp
Dec 24, 2024 10:48 AM
Jst4fun
Mar 5, 2021 07:16 PM
Brooklynite
NE For Sale/Wanted
Nov 10, 2015 06:42 PM
Digitz0070
Oct 7, 2015 12:43 PM
