CEL-after installing ground kit
Old May 16, 2004 | 09:14 PM
rx8daniel's Avatar
of course, a home-made kit. see my post in the Ground Wire thread (here: https://www.rx8club.com/showthread.p...946#post367946)
any pointers appreciated. my best thought at this time is: in the morning, cut all of the ties, remove my wires, check connectors OR buy a premade set to remove the guess work. TIA for any help!
Old May 17, 2004 | 06:08 AM
rx8daniel's Avatar
Old May 17, 2004 | 04:11 PM
rx8daniel's Avatar
bump again...
Old May 17, 2004 | 05:14 PM
JERCS's Avatar
Awesome Member
have you tried clearing your mem?
Old May 17, 2004 | 06:04 PM
rx8daniel's Avatar
I haven not. I don't know how. I've been searching here to find out. One mentioned removing batt cable for 20 secs; I do not have any reflashes, yet, so I can't do the 20 brake pedal press reset. Any other reset that can be done. Going down for dinner; will check my manual as well.
Old May 17, 2004 | 06:35 PM
zoom44's Avatar
remove the grounding kit and see if the cel goes away?
Old May 17, 2004 | 08:10 PM
RX-8 friend's Avatar
Did you remove the batt. -ve term. while installing? If so, you will have to reset the EPS (power steering). Turn wheel all the way to the ... etc. etc. - see manual.
Old May 17, 2004 | 09:07 PM
rx8daniel's Avatar
I removed the neg term for 20+ sec. that reset DSC; did the reset per manual. But I never started it - I went on to remove all of the ground set. Restarted, no CEL.
Will inspect the wires tomorrow in the light ; considering ordering gold connectors (when I find some).
Old May 20, 2004 | 11:48 PM
rx8daniel's Avatar
update: wierd! the light came back on today. Hasn't gone back off. I left the ground kit strapped in but had removed all the connectors Monday night. All the original grounds are as they were, the ground kit is not attached to anything. If anyone has ideas...please don't hesitate to post. Guess this w/e I'll try to... hmmm... re-do the OEM ground points to make sure they are connected correctly and tightly, try to reset again, although I did do that Monday night.
Old May 24, 2004 | 07:19 AM
rx8daniel's Avatar
update again: Installed Stage 1 yesterday ; no longer have CEL glowing. Had battery disconnected during install; did the DSC clear after restarting, all seems normal now.
Brooklynite
NE For Sale/Wanted
Nov 10, 2015 06:42 PM
Sakebomb Garage
Sakebomb Garage
Oct 22, 2015 04:28 PM
Tsurugi
Oct 4, 2015 02:33 PM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
