Mazda 626 Keeps Quitting
Old May 15, 2004 | 07:46 PM
Rick/Kimberly's Avatar
I know we're here for the 8, but my 2004 8 is running perfectly so far. But my winter beater ( which still gets driven on lousy days) keeps shutting down. Can someone direct me to a forum that discusses 626 issues. I'll outline the problem if someone has an idea. Runs fine on cool days. When temperatures are high it will run fine then all of a sudden quit. Let it cool for 15 minutes, it will run fine for another 10 and so on. It isn't getting spark. It's a 93 626 2.0L. Please don't yell at me.
Any help will be appreciated.
Old May 15, 2004 | 07:52 PM
snap-on's Avatar
http://www.mazdaworld.org/forums/
And you need a new distributer
Old May 15, 2004 | 09:31 PM
Thanks VERY much for the link. Didn't know it existed. I was leaning toward distributor but replaced cap and rotor first thinking heat would affect small arc tracks and possibly ground out. I appreciate the opinion- will search out a used one.
And thanks for not yelling.
Old May 15, 2004 | 09:39 PM
snap-on's Avatar
The CMP sensor is inside the distributer and as it heats up the sensor fails, hence the "no spark" condition.
and I don't yell.
Old May 15, 2004 | 09:51 PM
I don't expect that the CMP sensor is a seperately replaceable part. This is a whole distributor deal isn't it?
Old May 15, 2004 | 09:55 PM
snap-on's Avatar
Old May 15, 2004 | 09:57 PM
Thanks. Well said.
Old May 16, 2004 | 10:34 PM
CERAMICSEAL's Avatar
snap-on, my money is on it being the distributor also: FSO1-18-200 is the one.It's a hard one to find since it was only available in the 93 626, MX-6 and Probe 4cyl (also 5speed 94 models).
By the way, what's a CMP sensor? Is it the same as the ignitor because that's generally what fails with these.
Best of luck Rick/Kimberly.
Old May 17, 2004 | 08:10 PM
Thanks guys. Appreciate the input. Turns out it is the distributor and also turns out they are hard to find. From now on, I'll keep my 626 problems in the group they belong in.
Rick
Azki23
Jun 27, 2018 03:48 PM
Sakebomb Garage
Sakebomb Garage
Oct 22, 2015 04:28 PM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
projectr13b
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
