Pics of CZ Midpipe with Cat
Old May 4, 2004 | 07:57 PM
RXhusker's Avatar
Int-X 293WHP 242TQ :)
Here are a few pics -- I am installing on Friday.
Old May 4, 2004 | 07:59 PM
RXhusker's Avatar
Old May 4, 2004 | 08:02 PM
RXhusker's Avatar
You must not be able to post 3 pics in a row ?
RXhusker's Avatar
one more try
Old May 4, 2004 | 08:19 PM
RXhusker's Avatar
This is of course the CZ-MidP4 -- midpipe with resonator and 5" Random Tech high flow cat.
Old May 4, 2004 | 09:34 PM
adrian-1's Avatar
Ex- member.
Any chance you could get a sound clip with the CZ4 pkg + borla? I'm interested to see what it'll sound like.
Old May 4, 2004 | 10:04 PM
Omicron's Avatar
Mine should be here tomorrow. :D
Couple of questions though, since yours got to you before mine did...
Did it come with the bolts to mount the cat to the midpipe/resonator section? I would assume you could reuse the bolts from the existing cat section on either end, but this is a separate set of bolts. Oh, and did he provide the cat-replacement straight through pipe too, or do you have to buy that separately? Thanks...
Old May 4, 2004 | 10:23 PM
Xavier296's Avatar
Always tinkering
Wow, I was the prototype for this exhaust midpipe, and even I just saw the final version for the first time. I am glad that the 5" cat is being used, as well as a resonator. Otherwise the setup was very loud. And hopefully the 5" cat won't burn up like the 4" one did on my car. I did run a 5" cat for awhile though, and it seemed to work beautifully and checked out well. That 4" just didn't seem to like the rotary heat. Hope that resonator makes a difference!
Old May 4, 2004 | 10:26 PM
snap-on's Avatar
We need a dyno.
Or did I miss it somewhere?
Old May 4, 2004 | 11:06 PM
RXhusker's Avatar
Everything in the box is in the pic -- hope I don't need anything else.
Old May 5, 2004 | 08:49 AM
RXhusker's Avatar
Yes it comes with the bolts (2 mounting kits actually). Didn't come with the cat delete pipe -- must have to get that separately.
Old May 5, 2004 | 09:38 AM
Omicron's Avatar
Thanks guys.
Old May 5, 2004 | 10:11 AM
HottRodder's Avatar
Omi/RX- Does the CZ 1.1 need to be reprogrammed with this mod?
Old May 5, 2004 | 10:51 AM
RXhusker's Avatar
No - the new Stage 1 was already designed to work with the midpipe/cat. It does however allow you to go to the Stage 2 tune if you desire.
Old May 7, 2004 | 04:31 PM
RXhusker's Avatar
OK - got it installed today.
Observations:
Definitely a little louder - seems a little more than the 3db that CZ indicated
My package was short 3 bolts and nuts and the installer had to cut down the spacers for the spring bolts because they were too long. The new midpipe doesn't have the flange that extends into the back pipe so the gasket doesn't seat as tightly -- my installer thinks there is a small leak and wants me to check it out with CZ -- or he will weld in piece to make it like the stock midpipe. Also the gasket that was provided wasn't as thick as the stock gasket so my installer had to scrap the new one and reuse the stock gasket.
I plan on calling CZ on Monday and discussing.
My installer did say that it is very high quality materials.
Old May 8, 2004 | 02:06 PM
MrWigggles's Avatar
If you have any type of leak other than a microscopic sized one, it is going to be louder than it needs to be.
Keep us informed.
BTW, does it feel any faster?
-Mr. Wigggles
Old May 8, 2004 | 11:15 PM
RX-8 friend's Avatar
Hey, if it's noisier it must feel and be faster .
Old May 8, 2004 | 11:26 PM
RXhusker's Avatar
Went to the track today see write-up here the 8 felt great with the CZ midpipe and cat. Did feel a little more power and and top end felt less restricted -- spent a lot of time above 7k rpms and the engine felt like it wanted to rev more than it did with the stock cat/midpipe.
Old May 9, 2004 | 11:34 AM
Omicron's Avatar
The above referenced link is a good read folks. Check it out.
Old Jun 15, 2004 | 06:26 AM
tokenbrit's Avatar
6Spd Blue 230
Does anybody know if the CZ midpipe/resonator/high flow cat passes emissions tests?
Thanks.
Old Jun 15, 2004 | 07:22 AM
The_Bean's Avatar
According to canzoomer it will.
Old Jun 15, 2004 | 04:07 PM
SDFLY's Avatar
Right you are sir...highly recommended reading!
JimmyBlack
273
Feb 10, 2020 10:23 PM
qtipconnoisseur
Oct 29, 2015 07:19 PM
br0wm
Oct 24, 2015 11:06 PM
yapakanichi
Sep 25, 2015 07:55 PM
tgaffner
Sep 7, 2015 08:49 PM
