bizar sound
Old Apr 26, 2004 | 09:13 PM
rxmike's Avatar
bizar sound
my car cold i have a bizar sound from my clutch (i think) . have you the same problem guys? sorry for my english.
Old Apr 26, 2004 | 10:46 PM
Rotary Titus's Avatar
hmm think you need to be more specific (what kinda of noise? screeching? whirling? scraping? and when does it happen? idle? under acceleration?)
Old Apr 27, 2004 | 01:30 PM
kbull's Avatar
Senior Jackass
Maybe the ABS self-check? Could be mistaken as coming from the clutch, although it happens in all weather. More specifics needed.
Old Apr 28, 2004 | 07:36 PM
rxmike's Avatar
o.k at neutral when i slack the pedal of clutch.
Old Apr 28, 2004 | 07:41 PM
zoom44's Avatar
could be 2 things.
one it could be the throw out bearing rattle. this is normal for this transmission but some have had problems related to the bearing.
second could be the dynamic damper bracket on the transmission. did you have the recall work done for this dynamic damper yet?
Old Apr 30, 2004 | 07:48 PM
rx8ntexas's Avatar
I think I have this same rattle type noise...just started today...seems like it is coming from under my feet while driving...really notice it at low speeds...almost sounds like your driving over road reflectors...or maybe what it would sound like if you were driving with a flat driver side front tire...weird sound..haven't figured it out yet
Old May 1, 2004 | 05:45 PM
rx8ntexas's Avatar
rxmike,
I think this is the answer to both our problems:
http://www.finishlineperformance.com...er_recall.html
Old May 2, 2004 | 02:05 AM
rxmike's Avatar
rx8ntexas thanks my friend for your information but im not certain thats my probleme because i do this recall.this sound is just with my car cold and at neutral. sorry for my bad english
Old May 2, 2004 | 11:16 AM
wakeech's Avatar
mostly harmless
bonjour rxmike.
je pense que le probleme est avec le "bearing de throwout", ce qui est un bruit whizzing normal de cette conception de transmission.
excusez mon francais, je dois faites le programme traducteur.
Old May 3, 2004 | 10:16 AM
MyRxBad's Avatar
Fb's rock!
Is it like a screeching sound. Only happens when you first move the car? if so, mine does this too. I don't think it's anything to worry about.
92trbolzr
May 18, 2025 09:04 AM
theblinkof
Oct 4, 2023 05:24 PM
Digitz0070
55
Jul 25, 2017 08:40 PM
Racingjunkie
Sep 29, 2015 05:05 PM
tommy26Germany
Sep 29, 2015 10:33 AM
