stage 1.1 turned off but it's still active!
Old Apr 22, 2004 | 12:00 PM
emailists's Avatar
I still have the orig K flash I believe (getting M flash early next week).
I decided to install the CZ unit this week. as I posted in another thread, It is not compatible with K flash at all- major low RPM problems- upper was not too great either. OK this is to be expected since it is tuned for L or M flash.
What I didn't expect was that turning the CZ off, the low RPM was still rather poor. It wasn't unitl I pulled the unit out that the car returned to normal.
I did not step on brake peddle after either the install or de install.
Also odd thing is that turning wheel R&L did not reset the DSC until the car was turned off then on.
Also the ECU and Stage 1 unit get really hot!!!!
Old Apr 22, 2004 | 01:39 PM
jdl's Avatar
jdl
just jd.
Re: stage 1.1 turned off but it's still active!
The last part of the procedure from the Quick Tips says, "turn ignition OFF, then ON", so that shouldn't be too odd.
cliffkemp
Dec 24, 2024 10:48 AM
Shankapotamus3
Mar 14, 2021 03:53 PM
garryg
Australia/New Zealand Forum
Oct 1, 2015 04:54 PM
D13
Oct 1, 2015 07:55 AM
Racingjunkie
Sep 29, 2015 05:05 PM
