MrWigggles
02-08-2003, 03:08 PM
I calculate that from the press kit 290 liters equals about 10.3 cubic feet.
The press kit lists 7.6 cubic feet and that doesn't jibe with their 290 liter number.
For what its worth, I saw the trunk open at the Houston Auto show and 10.3 appears to be the closer figure.
10.3 is still smallish but 7.6 is very small
-Mr. Wigggles
ohhno15
02-08-2003, 03:30 PM
I though the trunk was fairly large, especially for a sports car and really inpressive considering it has 2 real backseats.
Buger
02-08-2003, 04:28 PM
Actually both numbers are correct. The actual volume of the trunk will greater than both the VDA and the SAE volume. The SAE volume is determined by the volume of the suitcases that can be put in the trunk. See attached:
Buger
02-08-2003, 04:29 PM
The initials VDA stand for Germany’s Verbund die Automobil Industrie. The trunk is filled with blocks each measuring 200mm x 100mm x 50mm which are not able to fit in oddly shaped areas.
The VDA volume is the volume of the blocks that can fit in the trunk.
oecher
02-08-2003, 04:53 PM
You are totally right, but it's called Verband der Automobilindustrie (http://www.vda.de/).
ohhno15
02-08-2003, 06:23 PM
How the hell did you know that?
-You should go to a car trivia night.
P00Man
02-08-2003, 07:25 PM
lol, crazy nuts
________
WELLBUTRIN DEATH (http://www.classactionsettlements.org/lawsuit/wellbutrin/)
Grimace
02-11-2003, 05:52 PM
And here I thought they just filled the trunks with water, and measured how much went in. :D j/k
Learn something new every day!
