Time for new brakes?
Old Mar 26, 2004 | 07:28 PM
j1mb0x99's Avatar
Caution!
Question Time for new brakes?
My brakes started squealing the other day. Normally, I wouldn't think nothing of this and just get some new brakes. My concern however, is that I don't even have 5000 miles on the car yet. This seems like pretty low mileage for a set of brakes. Especially since I don't brake hard and I don't ride the brakes either. How long are brakes soposed to last under normal conditions? Advice and opinions please.
-JiM
Old Mar 26, 2004 | 07:32 PM
Rotary Titus's Avatar
squeals could be due to sand or road grit between your pads, they might go away.
I've had slight squeals a month ago and now they're gone
Old Mar 26, 2004 | 07:50 PM
Morgan's Avatar
Lounge Sweetheart
I've had a lot of problems with my brakes..if you take it to the Ocala mazda in FL, they'll tell you nothing is wrong with your brakes and then magically, new rotors will show up on your car, but you won't notice them until you drive all the way home...
Ok..sorry--that was a slight vent..but i hear the brakes have some "issues"
mikeb's Avatar
100% Italian
mine make noise
there is a thread on this in the wheel section
Old Mar 26, 2004 | 08:15 PM
j1mb0x99's Avatar
Caution!
ok, thanks guys. I never look in the wheels section, but I'll have to check it out mike.
--JiM
Old Mar 26, 2004 | 08:23 PM
RX-GR8's Avatar
imine squealed and the dealer said i glazed the rotors. they resurfaced them and put new pads on. 2 days later squeal is back.
Old Mar 26, 2004 | 09:19 PM
crumpmd's Avatar
Stirring the pot
Get them inspected and replaced if there is any question
Old Mar 26, 2004 | 09:36 PM
Sue Esponte's Avatar
Grand Poobah
Squealing brakes don't necessarily mean the brakes are shot. Sometimes (as some have found - happened to me too) it's glazed rotors, sometimes its just the nature of the particular pad, or it could also be dust or grit...
If you're brakes don't feel right though or you're concerned then you should have them checked. Doesn't cost anything to be cautious.
-Eric
Old Mar 26, 2004 | 09:51 PM
red_rx8_red_int's Avatar
I have the squeal come and go. IMHO a couple of hard stops and the squeal goes away. For those with glazed brakes, is this from getting too hot?
MazdaManiac's Avatar
Generally, all it takes are a few really, really, really hard stops to clear it up.
Old Mar 26, 2004 | 09:52 PM
LOL, our posts crossed.
Old Mar 26, 2004 | 09:57 PM
RX-GR8's Avatar
not sure. i personally am a light braker but i do remember crunching them once this past winter. that may have caused it.
Old Mar 27, 2004 | 02:04 PM
magixpuma's Avatar
With such a high end car you think they would put high preformance rotars In my opinion Buy your self some drilled rotars so it will vent the heat alot better be4 anything gets warped beleive youll be much happier.
Old Mar 27, 2004 | 02:13 PM
winter's Avatar
Yeah, right up until they crack or start chewing up your pads. Most of the cross-drilled rotors you see for sale are just stock rotors that've been drilled... and trust me, the rotors are not designed for this. Even the good ones I'd only recommend for track use.
Old Mar 27, 2004 | 02:45 PM
magixpuma's Avatar
THx for the advice ill take that to heart
UHATEIT
Mar 31, 2019 05:31 PM
Solidtrance
22
Sep 4, 2015 12:47 PM
digitalmonkey79
Jul 29, 2015 12:09 AM
thewatcher101
Jul 27, 2015 09:44 PM
RX7.9
Jul 20, 2015 12:01 PM
