Problems with my 8, anyone else have them?
Old Mar 22, 2004 | 06:50 PM
jniamehr's Avatar
Young Rotor Head
Im having the same problem with the revving start-up and Im wondering if its worth the effort to go through to have the new plugs changed....
Old Mar 22, 2004 | 06:56 PM
zoom44's Avatar
leave the k&n intake off for awhile and see if you have any more problems. make sure the stock intake goes back on correctly. people who had that intake have had various problems linked to the MAF. perhaps whoever installed the k&n intake did not properly screen and/or position the MAF. what did the service person say the code was that lit the CEL.
Old Mar 22, 2004 | 07:53 PM
G8rboy's Avatar
Mmmmm... Rotary Donut
Troy-
It's definitely not the winter- there are plenty of RX-8's running around Canada and the northern US as daily drivers. You shouldn't have to touch the accelerator before, during or after starting the car (until you're ready to drive it of course). It sounds a bit like your plugs are slightly fouled- what are your driving habits like? i.e. Do you shift and/or cruise at low RPM's? How often do you really wind the motor out (8-9k RPM)?
If the answer to that last one is rarely, then I would suspect you could use new plugs. I would first try to burn that crap off 'em with several redline runs and see if it helps. Only once I felt a slightly rough idle, and after a redlining through first and second it was fine again.
My $.02
-Sean
Old Mar 22, 2004 | 08:40 PM
RXhusker's Avatar
Int-X 293WHP 242TQ :)
Troy -- have you gotten the "L" flash yet? I would occasionally have to really crank it to get it started when the temp was very cold -- since I got the "L" it has fired up with no issues. Have you tried doing the ECU reset operation to clear out what has been "learned"?
Old Mar 22, 2004 | 09:13 PM
G8rboy's Avatar
Originally posted by JeupRX-8
I haven't gotten any reflash. I have owned the car for 4 weeks tommorow. My dad is going to have a meeting with them tommorow, to discuss this vehicle, and what we are going to do with it. I am very cautious about cars, because if it is crappy already; it has a strong possibility to be a lemon. Just like my last 2 lemons.
Troy J.
That would be tremendously bad luck... stay away from my '8
Seriously though - get it flashed, and have them at least check the plugs. Hopefully the CEL code will also shed some light on things... maybe a misfire from the plugs.
Old Mar 22, 2004 | 11:33 PM
iamcanadian's Avatar
Follow Zomm44's advice, take off the intake and see if your problems disappear. Many on this board have had similar problems arise after making that mod.
BTW our 8 runs year round here in Canada and I have never had to touch the accelerator to light 'er up. My guess is that all of these probs may be related to the intake. Let us know. Good luck.
Old Mar 23, 2004 | 01:21 AM
Navybeardbb's Avatar
like someone said on another post, i like to rev my engine up to like 5,000 rpms and then wait about 10 seconds and then turn it off. It actually starts a lot better i was surprised when i tried it, but my friends think i am really weird when i do it hehe.
Old Mar 23, 2004 | 03:53 AM
KrustyKlown's Avatar
3 Lemmons?
Is the same person installing the upgrades on all your cars? If I was on my 3rd car because my last two were "lemmons" I would be dammed if I was going to start slapping mods on before I even broke the engine in.
Good luck with your 8 but I find the number of problems you have had with all your cars......suspect.
Old Mar 23, 2004 | 07:54 AM
Imp's Avatar
Imp
What's next?
Not really familiar with the 8's yet... I know one thing that's helped on cold morning with various Fuel Injected cars is to turn the key to the on position and wait 2 or 3 seconds for the fuel pump (you can hear it in some cars) to send fuel/pressurize the system and THEN try turning it over.
This way you're not trying to start it immediately with not much fuel readily available.
YMMV... but I used to have problems in cars that sat in 0 degree weather... once I started witing 2 second for fuel to be delivered... within 2 cranks the car is purring like a kitten.
Old Mar 23, 2004 | 09:09 AM
G8rboy's Avatar
This helps with the '8 as well... I usually wait until the third 'ding' sound after the dash lights up before I crank it past 'on'... which would give about 2-3 seconds for the fuel system to pressurize.
Old Mar 23, 2004 | 12:04 PM
6mm's Avatar
6mm
Lemons do exist.
For me it has only been VW and Audi.
Now, I will never buy their products again.
I've purchased several new makes and the only problem cars were the Audi allroad and the VW Golf.
These were all good:
Acura Integra
Toyota Tacoma
Land Rover Discovery II
Audi A4
Mazda Miata
Subaru Impreza RS
I am hoping my RX8 falls into the "good" column.
Old Mar 23, 2004 | 02:57 PM
911SC's Avatar
Uh, let me see if I understand you correctly. you've had the car four weeks, you beat the **** out of it and it has some aftermarket parts on it. You've also had problems with three other new cars. Maybe it's not the cars.
Old Mar 23, 2004 | 09:44 PM
Imp's Avatar
Imp
What's next?
Yes. If it blinks, then have it towed. Perfect advice.
Basically, a 'Check Engine Light' monitors your OBD-II programming on any modern car. All makes are required to have it for emissions, and various other 'checks' (there's hundreds of codes that a light can come on for). If it is solid steady, something that can effect emisisons will have the light engage. Get the car to a dealer or authorized repair facility As soon as convenient.
If there's something seriously wrong with the car, it'll blink. Pull over (where safe to do so) and call someone to come get the car. But then again, you'd probably feel it too... the car would be sluggish, or stalling. A flashing CE light will cause the car to go in "Limp mode" and shouldn't leave you stranded.... it'll only have about 1/2 the power....
I thought OBD-II and the Check Engine light would have been covered in your drivers manual... did you get one of those?
--KC
Old Mar 23, 2004 | 09:55 PM
English's Avatar
So many roads to ride...
Thanks for changing your avatar. Hope your car works out, but if it does not, just have daddy buy you something else, DUDE!
Old Mar 24, 2004 | 01:52 AM
I am not bashing the 350Z. I know there are a lot of you 350 owners here but a friend at work was telling me about his dad's 350 and said the the driver seat clicks when turning sharp left. Like it is loose and it slides into place almost. They also over tourqued something on the rear axle and it messed up the camber of the tires and caused the uneven wear on the rear tires. The dealer has been less than helpful fixing it. I know there are bad dealers just like lemmon cars (thankfully, for us anyway, the Jeup's seem to keep buying them all up ). Anyway this was posted more for the people that keep thinking the grass is so much greener on the other side of the fence.
Old Mar 24, 2004 | 10:35 AM
G8rboy's Avatar
Until you've had the dealer check the CEL and plug condition, I think you're jumping the gun on labeling your '8 a lemon. As I said earlier, it might be something as simple as fouled plugs causing misfires to light the CEL- not the end of the world.
I don't understand why your dad is going into the dealer talk to them, but you're not bringing the car in to get checked out. Many of us of had CEL's- some of them legit, some of them were from bugs in the previous PCM code- it's something you're going to run into with a first year car. I certainly didn't start crying 'lemon' when my CEL lit... I took it to the dealer to get checked out.
Old Mar 24, 2004 | 10:14 PM
Gord96BRG's Avatar
I am going to get a 350Z, because I have read of too many problems with this car, especailly in the winter. This engine is too tempermental for me, and the car is too slow. I have an auto, which has no tuning potential
Oh man, if you're going to a 350Z to avoid problems - think again. Maybe you ought to spend a few days reading at some of the 350Z forums - they have just as many niggly little problems, like chronic tire feathering issues, grease from the window tracks on the windows, interior trim problems, etc.
I don't know of what winter problems you're referring to with the RX-8 - be aware that any 350Z is also going to require separate winter tires, like the RX-8. Lots of us Canadians have been driving our 8s all winter with no problems. The engine isn't temperamental beyond the need to let it warm up for 3 minutes before shutting it off, and we could have told you right off that the auto was slow (note the auto, not the car). If your dad wouldn't let you get a 6 speed because it was too fast - why would he let you get a 350Z auto???
Methinks you're over-reacting. Then again, your daddy obviously has big bucks and is willing to spoil you - take advantage while you can.
Regards,
Gordon
