Radiator fans
Old May 10, 2012 | 12:54 PM
nuke0907's Avatar
Never Blend In
Radiator fans
When do the radiator fans turn on? Does one run continuous and the other off a thermostatic switch? Do they both run off a thermostat?
Reason i'm asking is because the last time i started my car, i noticed that neither fan was running after i started it. i wasn't able to let it run to let it warm up for me to check the fans due to other problems. I have a set of aftermarket fans wired in.
Old May 10, 2012 | 01:11 PM
They are controlled by the ECU, you might want to the relay though. Do you still have a Cobb tune installed? they won't be running unless it's up to temp. Did you try the AC?
Old May 10, 2012 | 01:24 PM
Jon316G's Avatar
Grasshopper
Originally Posted by nuke0907
when do the radiator fans turn on?
Old May 10, 2012 | 01:25 PM
Awesome, I need to get a real workshop manual.
Old May 10, 2012 | 01:30 PM
nuke0907's Avatar
Never Blend In
The car didn't warm up long enough and my AC system is depressurized. That answers my question though. they probably work i just didn't see them run and just a little worried.
Shankapotamus3
Mar 14, 2021 03:53 PM
olyrx7
Oct 26, 2015 09:23 AM
urbanvoodoo
Sep 30, 2015 12:41 AM
superROB23
Sep 4, 2015 01:22 AM
