Oil regulator problem with T618Z BNR
Old May 1, 2012 | 12:44 PM
fonzy's Avatar
Hi,
I have a Greddy turbo kit, with a BNR cutom kit in my Rx8.
When I mounted my turbo kit, I install the Mazmart Regulator Kit...
I look from my PLX Oil pressure gauge 7-8 BAR of pressure...
I have a big problem with my turbo.... I found a oil in in intercooler and all the circuit of turbo...and when i drive my car I feel a smell of oil...
Is possible the problem of my turbo is a strong pressure of oil ??
Please can you help me?
P.s.:sorry for my English...
Old May 1, 2012 | 12:49 PM
bse50's Avatar
#50
Non dovrebbe essere il regolatore il problema. Pm se vuoi.
Old May 2, 2012 | 09:19 AM
fonzy's Avatar
Thanks for response Bse
ok I want try with a oil restrictor...
Can someone help me with a specific with a oil restrictor for T618z BNR custom ??
thanks
Old May 2, 2012 | 09:28 AM
Most turbos only want about 30psi. Where are you running the oil feed line from?
Old May 2, 2012 | 09:55 AM
fonzy's Avatar
The oil feed start to oil sensor at driver side, and go to turbo with a normal oil feed of greddy turbo kit.
Why this question?
(or I have not understand the question)
Old May 2, 2012 | 10:02 AM
I was just wondering, some (me) run it from an adapter plate at the oil filter. I am not sure what the difference in pressure is at either location.
Are you running the Greddy drain pipe from the bottom of the turbo? Did you tap into the stock oil pan to return the oil from the turbo? have you had this kit installed for a long while or is this a new install?
Old May 2, 2012 | 10:18 AM
fonzy's Avatar
Now is about... 2500 km of turbo kit...when i install the kit i think is possible at new...
I have waintg...waiting... but now is not change... or is broken...or is for the oil pressur...
(sorry for my english :P )
Old May 3, 2012 | 05:11 AM
Brettus's Avatar
Boosted Kiwi
This should help :
https://www.rx8club.com/showthread.p...ght=restrictor
Old May 3, 2012 | 10:09 AM
fonzy's Avatar
OK i have read, but I not understand how is the hole diameters for a T618z BNR upgrade...is the same of MM upgrade 0.35 mm ?
Old May 3, 2012 | 03:13 PM
Brettus's Avatar
Boosted Kiwi
The BNR that you have is the greddy turbo which is the same turbo as in that thread so stick with that .
Old May 4, 2012 | 01:49 PM
fonzy's Avatar
I have make a question at Elliot of turblown and Bryan of BNR and the response is 0.059.
Now i try if is this the problem or not...
Old May 9, 2012 | 04:28 AM
fonzy's Avatar
I'm going creazy!!
HELP
what is the measure of the restrictor? 1/8 1/16? -3AN -4AN i not understand!
I want know a measure for remove turbo and try in one day...is not possible for me, remove the turbo, measure the hole of turbo and the hole of oil line...
I have original Greddy oil turbo line (i think is 1/8) and a t618 BNR upgrade
Can we help me for this measure?
Old May 9, 2012 | 10:37 AM
It should be a -4AN line, but could be a -3 AN. The restrictor comes in different sizes on the line side, but it is a 1/8 NPT and will screw inline with the "T" fitting greddy supplies. I am running this 0.65 restrictor from ATP.
http://www.atpturbo.com/mm5/merchant...de=ATP-OIL-022
Old May 9, 2012 | 12:21 PM
fonzy's Avatar
Thanks for this
But I think is better put in a turbo assy core...or not? and I dont know the measure for male to male...ok the line is 1/8...but i don't found 1/8 restrictor male to male...only 3-4 AN to 0,125...or 0,15 or 0,1 ....
Old May 11, 2012 | 10:26 AM
fonzy's Avatar
-News
I have made an oil restrictor
The step of oil line is 1/8 i have make with a grain in a normale male to female oil junction and i drilled it with 1,5mm hole
For now do not lose...
And the oil smell is decreased...
xAgyex
Jun 3, 2026 03:47 PM
RicerX1
Jan 11, 2016 05:59 PM
uZu
Dec 30, 2015 12:35 PM
foxyRoXy8
Aug 18, 2015 10:26 PM
MolsonB
Aug 18, 2015 08:42 PM
