gear grinding
Old Mar 15, 2004 | 09:36 PM
redhot04rx8's Avatar
gear grinding
Lately i noticed when getting on the car roughly around 6-7000 and higher rpm in second gear when i shift into third it grinds a little. If im up to about 5000rpm and shift to 3rd everything is smooth but higher than that it grinds, anyone know why this is? I know i should just bring it into service and i will i just have no time but ill get around to it eventually i just hate reving out 2nd gear til then.
Old Mar 15, 2004 | 09:49 PM
OBryanRX8's Avatar
happy rotoring
i would definetly be easy on the car and get in to a service department asap doesnt sound good keep me updated and good luck
Old Mar 15, 2004 | 11:23 PM
wakeech's Avatar
mostly harmless
Re: gear grinding
it's either you're shifting too quickly (forcing it into gear before the synchros can adjust the speed of the selector), or there is a definite deficiency with your gearbox.
try simply shifting slower: the higher your rpm, the more rpm you have to drop while you upshift, as the change in ratio stays constant. i'd worry if it was grinding no matter what you were doing (short of rev matching), at any rpm, on up and down shifts. but for right now it sounds to be a case of shifting m4d qU1c|< yo'.
Old Mar 16, 2004 | 04:49 AM
TheBuddy's Avatar
Does this mean you can't shift fast ? .... that kinda sux... how does this affect Auto-Xing ? I watch those videos and the japanese guys shift rather quickly while redlining, does this mean you will have to replace synchros more often ? what about tranny fluid ?
Old Mar 16, 2004 | 04:54 AM
TheBuddy's Avatar
Damnit it's been like 5 hours... answer me already... :-D
But seriously this is a random question about cookies....I think...
I logged in at the front page, went to this forum through the diff forum names... read the posts on the grinding... clicked "post reply" and typed all of this. clicked "submit reply" and it took me to the screen that says your not logged in...? I would log in again, and the screen where you type your post reply would pop up, with the things I typed... go to submit and would do same thing.. I restarted Internet Explorer and it works fine... what settings should my cookies be on ?
Old Mar 16, 2004 | 05:18 AM
WTF no turbo's Avatar
How many miles on your car?Ive been told 8s have a weak tranny which others have rebuted,but none the less mine is fried @14k.Take into service and have them look at it.Also dont forget about flywheel if you replace clutch,if your going to do it.
Old Mar 16, 2004 | 12:50 PM
wakeech's Avatar
mostly harmless
TheBuddy,
it doesn't mean you can shift fast, it means that those professional drivers have talent, while ham-handing your transmission is not going to do it any good. just slowing down while you shift your gears isn't going to lose you a race in auto crossing (as you do most of the course in 2nd or 3rd gears).
Old Mar 16, 2004 | 01:42 PM
Omicron's Avatar
Internet Explorer and this site don't always play nice and share their cookies. Best thing you can do is exactly what you did and log out and back in.
Old Mar 17, 2004 | 05:05 AM
TheBuddy's Avatar
I was just kinda curious. I do not have an RX-8, hopefully in late summer, but who knows. So I can't really say anything about them first hand, only what I see on videos. and I have seen them shift very fast when redlining, does this put more stress on the engine? how about the drive line ?
Very random, but could you tell me where I should post about a school I hope to be attending ? Just to get comments and suggestions of the school and maybe what I should try to do before attending.
P.s. damn the cookies
Old Mar 17, 2004 | 11:50 AM
wakeech's Avatar
mostly harmless
yeah, that technique you've seen them do is "power shifting", and Judge Ito (member here, and maybe also at rx7club.com, and a heavy/moderator over at "the other" place... nopistons.com) has broken his transmission doing this whilst looking (and finding, IIRC) for mid 14's in the quarter.
it's really hard on the synchros, it's really hard on the selectors, and yeah, it's not so easy for the engine (but won't bust it up as bad as all that). it's really an extremely advanced technique and not exactly necessary outside of the highest echelons of competition.
anything that's not to do with cars goes in the lounge so that's pretty much your "everything" section.
...and i like cookies, especially choco-chip and gingersnaps :p
and internet ones are pretty cool too, just stop using crappy microsoft products
Old Mar 17, 2004 | 02:24 PM
Master Tech's Avatar
You may want to have your dealer chech your pressure plate bolts.
I have found some lose . You can get to them by removing the starter .
Old Apr 3, 2004 | 03:45 PM
Well i brought the car in for the 2 recalls and told them about the problem shifting that i told you guys. A day goes by at the dealer and no call so the next day i call them to see whats up and they say, your car wont be ready til monday cause a new transmission is being delivered for your car. I was kinda suprised it needs a new trans, but no complaints from me. I told them do what you gotta do. Its not so bad cause when i dropped it off they gave me a loaner, a yellow mazda 6 with only 700 miles on it, still has them temporary plate. So ill just have fun and beat the crap out of that car til i get mine back.
Old Apr 3, 2004 | 04:35 PM
r0tor's Avatar
mine was starting to grind going into 2nd gear. I took it to the dealer and they said it was fine. I thought they were BS'ing me. I stormed out of my car and started driving and everything was fine. Then it was grinding again. ...
I found out I'm retarded and somewhere along the line lately I developed a habit of pulling the stick hard to the left and then down when shifting from 1st to 2nd, which apparently the linkage doesn't like as it binds up and the gears like even less as they grind... I pull straight back now and everything is fine :o
Old Apr 3, 2004 | 10:06 PM
Texas 8's Avatar
Integrity First...
I developed the same bad habit. Going to counseling as we speak and all is good.
"Hi, I'm Greg and I'm a shitty shifter" :D
Old Apr 4, 2004 | 02:12 PM
jaybraveheart's Avatar
Same Problem
I just took my 8 in for the same problem!!! The dealer hasn't gotten back to me. Was there any ?'s asked....Warranty issues.
Old Apr 4, 2004 | 03:27 PM
r0tor's Avatar
Pleased to meet another shitty shifter :p
theblinkof
Oct 4, 2023 05:24 PM
nowakm99
Oct 9, 2015 07:10 AM
Luke.s
Sep 30, 2015 05:57 PM
Zube6115
Sep 30, 2015 12:57 PM
juicemantwon
Sep 26, 2015 12:30 PM
