which turbo to use
Old Apr 18, 2012 | 10:38 PM
latty1183's Avatar
which turbo to use
whats up guys, ive done a lot of looking around and really i just straight up dont know what turbo kit to get, the greddy ive been told doesnt really have enough airflow, but thats just what ive been told, soooo i figured why not ask all you guys and whatever the most popular kit is ill just pick that one, esmeril i didnt really like to much because of the whole battery and movin **** all over thing, really im between greddy and sfr if the whole greddy rumor that ive been told isnt true then itd make it a better contender let me know guys thanks.
Old Apr 19, 2012 | 12:33 AM
bose's Avatar
Reginald P. Billingsly
What do you mean by a lot of looking around??? By the sounds of it you probably just searched for "best turbo kit" and couldn't find an answer on a silver platter so you decided to start a new thread in the hope that some one will just spoon feed you. Right?
Old Apr 19, 2012 | 12:41 AM
EricB's Avatar
#225 of 1000
If you dont want the hassle of moving youre battery then you wont be able to handle the hassle of a turbo.
Old Apr 19, 2012 | 02:04 AM
bse50's Avatar
#50
You didn't mention turblown...
Old Apr 19, 2012 | 03:03 AM
the one that goes "zoom-zoom" ....
Old Apr 19, 2012 | 07:14 AM
wcs's Avatar
wcs
no agenda
WERD +1
I thought the SFR kit had the battery moved as well?
So ... did you know that with the SFR kit you have the OMP removed?
I guess you have no problem with that, right?
Old Apr 19, 2012 | 01:24 PM
latty1183's Avatar
deleted-zoom44
Old Apr 19, 2012 | 01:31 PM
bse50's Avatar
#50
Turblown's low mount.
/Thread
J8635621's Avatar
Pew Pew Pew
Mazsport type 3
Old Apr 19, 2012 | 01:34 PM
wcs's Avatar
wcs
no agenda
edit- removing quoted. zoom44
I would not like having to premix all the time and I still believe the OMP is a useful device in keeping the apex seals cool.
I wish it did a better job at cooling the corner seals.
Moving the battery to the trunk is simple, probably the simplest thing to do on a turbo build.
Turblown has a pretty good rep around here.
What is it you didn't like .. Don't like the Top Mount design?
edit --
BTW I'm running a top mount T04e-60
I'm running well at 11 psi, think I've exhausted the spring on my WG
Going to try and get to 15 psi with a different boost signal setup
The lag is pretty huge below 4000 rpm but once your over 4500 rpm it spools pretty quick
Old Apr 19, 2012 | 01:58 PM
ShinkaEvo's Avatar
Triangular Bee Hive
It would be more like "boom-boom"
Old Apr 19, 2012 | 05:11 PM
Harlan's Avatar
I'm planning out a rear mount twin T25, draw through with water injection and no intercooler. But I'm out to blow up my engine and somewhat crazy. If your are questioning which is the best kit, then you don't know enough yet to go turbo without blowing up your engine.
Old Apr 19, 2012 | 05:16 PM
RX8Soldier's Avatar
Time for boost...
Read the stickies in this sub-forum to get an idea of what forced inductions is, and why turbo shopping isn't like shopping for a new purse...
Old Apr 20, 2012 | 06:11 AM
/Thread
You mean the one that hasn't been released yet for which there are zero results?
classic forum thought process at work ....
Old Apr 20, 2012 | 06:17 AM
bse50's Avatar
#50
Yes, the one i have spent a lot of time discussing with Turblown in the past.
Low mount, tubular manifold and turblown's quality. Turbo kit aren't rocket science, it's just that most manufacturers are less than trained monkeys while Elliott isn't.
That's why we're installing his kit on a fd3s in the following weeks. lol.
Old Apr 20, 2012 | 09:31 AM
An FD3 is not a Renesis/RX8, you are still talking out your tailpipe regardless
Old Apr 20, 2012 | 09:47 AM
bse50's Avatar
#50
Building a turbo kit for whatever car requires the same skills: welding and a little engineering.
Turbo choice may be different for a renesis because of the different exhaust pulsation but that's marginal as turbos\impellers\whatever can be changed out fairly easily to better suit one's needs.
As long as it's a low mount built with quality products and a tubular manifold it's ok. MAF friendly is a plus if one prefers an AP over a standalone. -> Turblown's kit is the only one that fullfills this criteria.
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
JimmyBlack
273
Feb 10, 2020 10:23 PM
Shnifty
23
Dec 18, 2015 12:49 PM
MolecularConcept
11
Sep 29, 2015 09:21 PM
