High pitched noise on acceleration
Old Mar 15, 2004 | 01:22 PM
MyRxBad's Avatar
Fb's rock!
Where is it coming from?!?
Old Mar 15, 2004 | 01:28 PM
XeRo's Avatar
Normality is Obscene
you have an aftermarket amp and sub setup?
Old Mar 15, 2004 | 01:44 PM
XeRo's Avatar
hmmm...there goes my theory...and if you say it was happening before you put the Grounding Kit on then I'm really at a loss...good luck with that one...
Old Mar 15, 2004 | 03:00 PM
Mr M's Avatar
Evolution of REvolution
Does the sound change with engine speed, or vehicle speed? Sounds like a vacuum leak to me.
Old Mar 15, 2004 | 03:47 PM
Gyro's Avatar
Rotary Abuser
some old post's to consider....
Here
and
Here
and
Here
I'm not sure if thats what your hearing.......hope it helps
Old Mar 15, 2004 | 04:11 PM
Gyro's Avatar
Rotary Abuser
Also the recall that changes the dynamic damper heat shield addresses a loose or fractured heat shield. This can cause a noise at certain RPM's.
If you havent had the recall work done yet......theres a good chance it could be the faulty heat shield.
Recall
Old Mar 15, 2004 | 11:30 PM
Kas's Avatar
Kas
- Senior Menber -
i've got the exact same noise. open your hood, start the car and play with the throttle revving it fast and slow. you will notice that the intake whistles loudly when it sucks air in. my engine runs real sweet so i've not bothered to look into it any further.
Old Mar 15, 2004 | 11:33 PM
Mr M's Avatar
It would be nice if you could compare to another car just to make sure it 'is' an abnormal noise. Not suggesting you are imagining anything, but it would be nice to rule out the possibility that this is a normal noise.
If it is a vacuum leak, then your only resort is to have someone rev the engine while you search for the source of the noise under the hood. All the intake air valves bar the auxiliary air work on vacuum, and another possibility could be the air line to the oil injectors (not vacuum). A job for the dealer me thinks...
Old Mar 17, 2004 | 04:38 AM
Charles R. Hill's Avatar
Owner of BHR
I have the same sound, I believe. My friends say it sounds like a turbo winding up. I think it might be the e-shaft and rotor gears making that sound. They have straight cut gears/meshing involved. In that case, the noise is normal. I tend to think it is one of the unique qualities of the rotary engine and I sorta like it.
Charles
Old Mar 17, 2004 | 09:32 AM
Psylence's Avatar
Back in the family
I know the noise your speakin' of, it's a slight whistling noise, right?
Mine does it too. It sounds like it could be gear whine.. it doesn't sound mechanically catastrophic so I'm not concerned.
Old Mar 18, 2004 | 08:15 PM
sup3rbad's Avatar
Numbah 1 in da hood... G
I asked about this soungd ages ago on this forum but noone gave me a clear cut answer. I hardly notice it anymore though. It's usually most prevalent when im in sixth gear trying to accelerate on a slight uphill.
Old Mar 18, 2004 | 11:47 PM
rx-7~rx-8's Avatar
Junior in High School
HOSE LEAK...
My Parents Jeep is in the SHOP... for the same thing... at higher speeds it seems like a whistling... noise... irritaing as heck... kind of like a ballon escaping air AS YOU MENTIONED..
-Vacumm Hose Leak... Possible from tranmission...
my tranny shifted perfect... but at high speeds it made tht sound... dont worr you have about 10K miles to fix it... if you delay it for a long long time say 20K miles it will not shift...
Mane
Nov 20, 2015 12:16 PM
tommy26Germany
Sep 29, 2015 10:33 AM
Learners_Permit
Sep 27, 2015 07:38 PM
Hiroshima_RX
Sep 21, 2015 06:28 PM
