custom driveshaft?
Old Apr 3, 2012 | 10:09 PM
rxsevenor8's Avatar
Chris
NY custom driveshaft?
what are some of the best companies to do custom driveshaft making? im located in long island NY looking for local or a company i can give measurements too over the phone.
chris
Old Apr 4, 2012 | 01:21 AM
bse50's Avatar
#50
try thoroughconcepts, mazdatrix also has one readily available. After these 2 companies you can try almost any shaft shop as they only require basic measurements and tq ratings.
Old Apr 4, 2012 | 03:39 AM
mavictb's Avatar
stock is carbon and pretty light i thought....
Old Apr 4, 2012 | 04:36 AM
bse50's Avatar
#50
It can be made roughly 900g lighter. Not much if you consider the MOI\diameter of the shaft and how the weight is distributed.
What if he needs a heavier shaft though?
Old Apr 7, 2012 | 07:50 PM
rxsevenor8's Avatar
Chris
I j need one to hold more power
Old Apr 8, 2012 | 12:13 AM
WingleBeast's Avatar
HAVOC
whoa whoa whoa, are you telling me you are breaking driveshafts with whatever setup you have? Or is this just part of a planned upgrade? I thought the stock could hold up to around 450hp
Old Apr 8, 2012 | 01:27 AM
Ernest63's Avatar
I need one...
Old Apr 8, 2012 | 10:48 AM
rxsevenor8's Avatar
Chris
i herd the same about the stock but i need one regardless with the new set up i have, i need the driveshaft, 2in shorter with the new transmission im putting in. and i want one that will also last the power in the long run.
Old Apr 8, 2012 | 05:21 PM
bse50's Avatar
#50
how much tq?
Old Apr 9, 2012 | 12:26 AM
rxsevenor8's Avatar
Chris
not sure yet of numbers
Old Apr 9, 2012 | 03:35 AM
bse50's Avatar
#50
so why look ad driveshafts when yours will most likely hold up fine? why even look at transmissions?
How can you build a car without a goal? that's recipe for disaster.
Old Apr 11, 2012 | 01:35 AM
rxsevenor8's Avatar
Chris
i didnt say i didnt have goals... quite the opposite. and i do need a custom driveshaft because i am putting a REW in my 8... not something the stock could bolt up too hah
Jazzmeson
RX-8 Multimedia/Photo Gallery
11
Mar 2, 2016 02:25 PM
Brokegang
Jan 3, 2016 12:45 PM
projectr13b
Rotary Swaps
Sep 21, 2015 04:52 PM
