ANyone have a clicking noise upon startup?
Old Mar 14, 2004 | 09:15 PM
kstkrt's Avatar
Hey all....new member here.....Just got my BLACK RX8 Base 6 speed.
Does anyone notice a clicking noise when first starting the car?
It last for a couple of minutes until the car is warmed up.
Once warm its not noticible.
Thx,
Jeff
Old Mar 14, 2004 | 09:57 PM
TheDosDog's Avatar
Recovered Modaholic
I hear the antilocks initializing and an occaision solenoid (depending on temp) but nothing that last for a few minutes. Can you tell where the noise is coming from?
Old Mar 14, 2004 | 11:16 PM
Kel Rx8's Avatar
if your not 1st your last
i heard something today ran to the garage started her up
came down like 5-7 min later
i had to get something out of a drawer which is by my passenger
side wheel and i heard it.i was basically on the ground when i heard it and seemed strange but didnt think much of it.
probably a solenoid.
Old Mar 15, 2004 | 07:34 AM
kstkrt's Avatar
I found out what it is.......its something to do with thte clutch.....cuz when I depress the clutch, the clicking goes away.....
A funny thing it is....Why would the tranny/clutch click when not warmed up, but go away when warm?
Is this anything to worry about?? Is it gewtting the proper lube when cold?
JEff
Old Mar 15, 2004 | 09:46 PM
Kel Rx8's Avatar
kstkrt
sounds like a throwout bearing
im having that noise also
but thats not the problem i was talking about in earlier post.
Old Mar 16, 2004 | 12:31 AM
Xyntax's Avatar
THREAD KILLER
A/C ?
Old Mar 16, 2004 | 12:35 AM
Hou-TX-RX-8's Avatar
I am glad to hear someone else has a noisy throwout bearing.
Nat
Old Mar 16, 2004 | 09:20 AM
kstkrt's Avatar
IS the noise just normal....or is it something that needs to be evaluated......
Mind you it does diminish greatly (barely noticible) one warm.
(and diminishes completely when I depress the clutch)
Old Mar 16, 2004 | 08:27 PM
Master Fuol's Avatar
The throw out bearing is very load in most of the RX8's. If the bearing is bad it will make a bad noise in the loaded position clutch in position not the neutral clutch postion. Mine does the noise thing. If I put just a little pressure on the petal it goes a way. There just isn't enough pressure on the bearing to keep it from making a noise.
Old Jul 19, 2004 | 04:48 AM
vibec's Avatar
clicking noise
I too have a clicking noise on startup
it seemed to occur after about 3-4000 km.
most noticable when the car is cold and dissapears (almost) when car is warm.
the clicking noise is not unlike tappet noises i used to get on my old mx5, and gets faster if the car is reved faster.
only noiticable from outside the car and does not get into the cabin when the windows are up.
the dealer couldnt spot it (the car was warm)
Old Jul 19, 2004 | 05:44 AM
dirtylittlepaws's Avatar
Had my 8 for two months now and i heard a clicking/knocking noise after startup for the first time yesterday.
Old Jul 19, 2004 | 04:36 PM
beachdog's Avatar
Metering oil pump
https://www.rx8club.com/series-i-tech-garage-22/hiroshima-i-think-we-have-lubrication-problem-34468/
Mane
Nov 20, 2015 12:16 PM
Danield97
Oct 10, 2015 05:58 PM
nowakm99
Oct 9, 2015 07:10 AM
tommy26Germany
Sep 29, 2015 10:33 AM
Jb4ker96
Sep 27, 2015 10:06 PM
