Catalytic Converter Mod
Old Mar 19, 2012 | 11:39 AM
Bauwz's Avatar
Ive have tried a search and struggled to find anything but again if the question has been answered else where give me a PM and I will get get the thread removed.
Anyway, ive tried looking for pictures of UK catalytic converters on rx-8's and I have struggled to find any with the correct angle to determine if the cat is a straight through design or an offset one. Ideally what I would like to experiment with is hollowing out a cat and welding a pipe straight through (basically making a de-cat through the original housing) this would mean any visual inpsections of the car for any reason would indicate the cat is still there and it would also remove the risk of destorying a good (and expensive) converter if plugs or coils fail. The original item would be kept for emmisions testing as required once a year.
Also do cats get refurbed or is a dead cat a trash item? Obviously I don't want to ruin a good item which like I said I would need for emmisons tests so getting a cheap dead item would be the only way to make this viable.
Old Mar 19, 2012 | 11:54 AM
bse50's Avatar
#50
You can do that.
Old Mar 19, 2012 | 11:56 AM
Bauwz's Avatar
Originally Posted by bse50
You can do that.
straight forward answer! thanks
do you know if dead converters are scrap items or not?
Old Mar 19, 2012 | 12:20 PM
bse50's Avatar
#50
There may be who refurbishes them but i doubt they'd build anything worth having on our cars.
Old Mar 19, 2012 | 12:27 PM
HiFlite999's Avatar
In the USA according to my dealer, cats are 100% returned to Mazda. Buying one outright w/o a return is about double the already-huge cost. If true, then never throw one away.
Old Mar 19, 2012 | 12:55 PM
alnielsen's Avatar
If your going to punch out the honeycomb interior to the converter, why go through the trouble of putting a pipe in there. Just run it empty.
Better yet, buy a burnt out/clogged one (to be modified) and sell the good one to someone that needs it. You should make a bit of money on the exchange.
Old Mar 19, 2012 | 01:23 PM
Bauwz's Avatar
This was my worry, I think they use platinum in cats which mazda my be able to get back from ruined units?
I need a cat to get past emissions test every year, which is a big reason I was going to try buy an old one to modify, so in the event my coils or plugs go I wont destory a good cat and cost myself a fortune!
The reason I would use a pipe through it is to maintain more efficient exhaust flow.
Old Mar 19, 2012 | 01:24 PM
1.3_LittersOfFurry's Avatar
Flame On!
^ he needs a good one for testing once a year.
Edit- Beat me to it.
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
RXFEVER
Aug 29, 2018 10:14 AM
RXFEVER
Sep 11, 2016 02:51 PM
PTQLam
May 23, 2016 11:17 AM
FubarI33t
Sep 28, 2015 08:45 PM
