Use Series2 OMP when rebuilding a Series1 engine
Old Mar 11, 2012 | 06:04 PM
AAaF's Avatar
Is it any of you guys who have used Series 2 OMP, and thereby a S2 rotor housing, when rebuilding?
My understanding is that S2 has three OMP nozzles, while S1 has two. I guess they didn't do that just for fun. So, since I'm planning a rebuild, I was wondering if a S2 "upgrade" would be a lot of work or a good idea. Piping would definitively had to be re- done, two extra injectors, and i guess the "lump" pipes are connected to needs to be from a series2 as well, but does the OMP it self have to be replaced?
In general: Do any of you guys with more knowledge think it is a good idea?
Old Mar 11, 2012 | 07:16 PM
no it's NOT a good idea.
why? cuz it will NOT work.
You need to double the oil pressure, re-work all the electrical wiring.
if u want more protection just premix, it's better than ANY OMP anyway.
Old Mar 11, 2012 | 08:16 PM
PhillipM's Avatar
But do whack the S2 water pump on whilst you're there.
Old Mar 12, 2012 | 06:49 AM
front housing is different ?
Old Mar 12, 2012 | 08:27 AM
PhillipM's Avatar
It only needs one bolt hold filing out slightly.
Old Mar 12, 2012 | 08:37 AM
AAaF's Avatar
Double the oil pressure, really? Why? I've understod that OMP just sip oil from the pan, then press the oil out of the nozzles by itself. Have I gotten something totally wrong, perhaps?
By rewiring you say that the series1 and series2 OMP is different?
And I register that people are split regarding premix vs OMP. Personally I do not think that premixing gives as efficient lubrication of sideseals as OMP. I run both to get as god lubrication as possible "all over".
Old Mar 12, 2012 | 08:59 AM
bse50's Avatar
#50
It's not just about rewiring. the s2 oil pump is completely different, it would be pretty tricky to run it with the OE s1 ecu.
Just forget about it and premix while cranking up the s1 omp values with an accessport or fiddle with its stepper motor.
Old Mar 12, 2012 | 02:34 PM
AAaF's Avatar
Great, thanks for the info.
One less thing to think about.
Old Mar 12, 2012 | 02:52 PM
This thread gets the stupid thread of the day award. Congrats.
Old Mar 12, 2012 | 03:06 PM
AAaF's Avatar
Thank you.
What part in particular gives me this honor? Asking a question I actually not know the answer to? I'm so sorry........
Old Mar 12, 2012 | 03:10 PM
TX
Originally Posted by AAaF
Thank you.
Because had you searched for five minutes about the S2 engine and oil metering system you would have realized getting the S2 OMP system to work on an S1 is damn near impossible without swapping quite a bit of parts and spending a ton of money.
Old Mar 12, 2012 | 03:14 PM
just ignore 9k, he is a well known a hole on this forum.
See? im so nice to noobs
Old Mar 12, 2012 | 03:31 PM
TX
You mean you are so nice to *****, because you sure as hell are not being nice to noobs today.
Old Mar 12, 2012 | 04:07 PM
AAaF's Avatar
When you're at it: just take your kid out of school and give him a laptop. Everything he's supposed to learn is at the Internet.
I ask dumb questions who "everyone" knows the answer to, because there are always someone else who has the same question. And when it comes to the test it shows time after time that the one asking "dumb" questions come out on top. So I'm not afraid of asking questions, as I do not need your or anyone else's approval in any way, a good thing about confidence.
What annoys me is your lack of common politeness. But as your post count suggest, you don't know when to shut it.
vapor2
Nov 3, 2020 03:38 PM
uZu
Dec 30, 2015 12:35 PM
Shnifty
23
Dec 18, 2015 12:49 PM
dbarber
Jul 25, 2015 01:34 PM
thedragonrotar
Jul 22, 2015 08:46 PM
