Will laminex overlays help with my issue?
Old Mar 5, 2012 | 01:19 PM
EightCostsMoney's Avatar
Question Will laminex overlays help with my issue?
When I bought my car my head lamps were really fogged up real bad. I tried have them restored a couple of times and they never cleared up. I decided to buy some sand paper and try it myself. However, I used too much grit on one and it scratched it up real bad. They are clear now except for the deep scratches on one lens. If I wax them with some clear wax like Turtle Ice is works for a day or two and just fades back to awful scratches.
I was thinking of getting some overlays like clear, slightly tinted, or even yellow to put over the lenses to help mask the damage. I was thinking of a heavy polish and make a seal the wax in the cracks. Then put the overlays over to seal it in and make it flat again. You think that will work? I do not have any money for new head lamps right now and looking for a cheaper fix till I can afford a new set.
If not, does anyone have any better ideas?
Old Mar 5, 2012 | 01:42 PM
Get some 800, 1500 and 2000 and finer if you can find it grit wet and dry paper and WET sand them until the scratches are gone.... then polish with a buffing wheel and they will come up nice
or take it to a body shop and get them to do it.....
Old Mar 5, 2012 | 01:45 PM
paimon.soror's Avatar
You dont want to do this depending on what type of sealant or polish you use, you are going to get some marring after a few days, it wont look hazy, it will end up looking blurry heh. Like dannobre said, get multiple grits of wet sandpaper up to 2000+, and take your time on each headlamp. And by wetsand we mean water with a tad bit of dishsoap for lubrication, or use a detailing spray. it will be 1000x easier to remove the light assembly, but if you cannot, be sure to mask off around the headlights.
Old Mar 5, 2012 | 01:52 PM
Yeah, tried that 3 times, with wet sanding! I accidently used a deep cutting grit on the first try; it might have been 80-100. I had an assortment pack and just picked up the wrong one. There are a few real deep scratches that are near impossible to get out. By the time I grinded that down I might not have lenses left. I can go by a body shop and see what they say I guess. All I know is it is almost a lost cause. It might be time to pay the stupid tax and just buy new set of lenses.
Old Mar 5, 2012 | 01:59 PM
it would take some significant sanding at like 25 grit (which is lierally just pebbles slapped onto a piece of paper) to sand all the way through the lens by hand lol
Old Mar 5, 2012 | 02:32 PM
It looks like that might be the ticket. I am going to go by a body shop on the way home and see how much it will cost to grind it down. If it is really expensive I'll do it myself. However, I have already proven to not have the skill to fix it.
Old Mar 6, 2012 | 05:58 AM
I took by a couple of shops on the way home. They told me that it had been scratched down to the clear. Not much I can do at this point to fix it. I'm just going to save my pennies and just get a new set of lamps. Thanks for the input.
Old Mar 6, 2012 | 08:58 AM
RX8Soldier's Avatar
Time for boost...
check the FS section. I know that I've seen some headlamps for sale recently.
Old Mar 6, 2012 | 09:13 AM
Brettus
Series I Engine Tuning Forum
46
Apr 19, 2024 06:28 AM
JimmyBlack
273
Feb 10, 2020 10:23 PM
LB2739
Jul 9, 2019 02:25 AM
Irvinb16
Sep 11, 2015 10:27 PM
