warm A/C issue.
Old Feb 28, 2012 | 06:25 PM
Snake74's Avatar
warm A/C issue.
So, I'm noticing that as of the past week, the air from my vents is coming out warm. My RX8 is a 2005 AT model with 57,000 miles on it. I've had it for about 5 months with no problems up until this.
I have checked to see if the problem was the temperature **** with that display trick but that doesn't seem to be the problem. I always have the settings on recirculation, dash only intake, and usually run it on 2. I don't have warranty on it because I got it from craigslist and had my mechanic check it out when I bought it; he said it all checked out fine. Might this be a compressor issue? I never had a compression test done because I don't have the money.
Old Feb 28, 2012 | 06:55 PM
godesshunter's Avatar
Voids warranties
Do a search. The topic has been covered many times. Besides, its February. You should have the heat on.
Old Feb 28, 2012 | 06:58 PM
Snake74's Avatar
Not when I live in Florida. I have already done many searches but I find that often times, I don't understand the jargon they're using. I'm not too mechanically inclined when it comes to names. I have always "played it by ear" with the previous cars I have owned.
Old Feb 28, 2012 | 07:25 PM
Voids warranties
Check out post # 2
https://www.rx8club.com/series-i-tech-garage-22/rx8-ac-problem-169723/
Old Feb 29, 2012 | 12:08 PM
EDZRIDE's Avatar
2005 White GT
It could be a lot of things; most likely it's low on freon. Have your mechanic check it out.
92trbolzr
May 18, 2025 09:04 AM
cliffkemp
Dec 24, 2024 10:48 AM
theblinkof
Oct 4, 2023 05:24 PM
Eliseo Esquivel
Sep 30, 2015 08:28 PM
DG07
Sep 28, 2015 10:58 AM
