bearing noise and not from transmission
Old Feb 26, 2012 | 06:06 PM
Z0oMzo0m's Avatar
I started car up today, started ok.. idles ok.. well i went to take off and when i got to about 3k rpm, i was hearing a bearing sound like one has failed, or about to fail. i turned around went back home. If i hold rev at 3k i can hear the sound, and its a steady vibration/bearing sound. If i rev from idle to 5k and let off you hear it when you depress the gas pedal. (i know what my throw out bearing sounds like) its not that.. possible pulley?
Possible i have a bad internal bearing? It was not there last night.. i cant see it happening over night just sitting.. lol
let me guess.. video for help? i can get that just not atm..
2007, 89k miles. new coils/plugs.. within 1k miles.
Any ideas?
Old Feb 26, 2012 | 08:38 PM
Z0oMzo0m's Avatar
i guess this hasnt been posted before.. i havent received a "search" or "another one of these" yet..
Old Feb 26, 2012 | 09:01 PM
Check the idler pulley on the AC belt
Old Feb 26, 2012 | 09:37 PM
Z0oMzo0m's Avatar
I took all the belts off car and the noise is still the same. Its a littler quieter but is there and noticeable. Not the heat shields on exhaust..
Old Feb 26, 2012 | 09:41 PM
Z0oMzo0m's Avatar
Only work I did today on car was Install rr oil filter relocation, and put the middle bracing in on the 6 point gt spec strut tower in. But I have had that 6 point for a while.
Old Feb 27, 2012 | 12:06 AM
Little too vague I guess......
Old Feb 27, 2012 | 08:39 AM
Bladecutter's Avatar
Rockie Mountain Newbie
Post a video for us to listen to, and don't talk or play the radio while the camera is recording.
BC.
Old Feb 27, 2012 | 10:12 AM
Z0oMzo0m's Avatar
i tried several different video clips, NONE of them sound good enough to put up here, there is to much motor/static noise over the sound on the clip. (new phone to)
Old Feb 27, 2012 | 10:38 AM
Z0oMzo0m's Avatar
Old Feb 27, 2012 | 10:40 AM
Z0oMzo0m's Avatar
First video was at a nuetral, revving to 3-4k (and holding a rev at 3k)
second video was driving went to 5k
Old Feb 27, 2012 | 12:51 PM
stinksause's Avatar
The Stink w.o The Sause
Any new vibrations? I am afraid may be e shaft bearings? Did you ever have oil leaks? What weight do you use?
Old Feb 27, 2012 | 01:15 PM
Z0oMzo0m's Avatar
No new vibrations, have used 5-20 since day one. No oil leaks, premixed the last 2-3k miles with protek
Old Feb 27, 2012 | 06:26 PM
Have you tried clearing the ESS Profile to see if that changes things somehow?
BC.
Old Feb 27, 2012 | 06:31 PM
Z0oMzo0m's Avatar
No I have not, I can try tomorrow unless the shop I'm bringing it to says other wise..
Old Feb 28, 2012 | 01:28 AM
Z0oMzo0m's Avatar
Here is another video, sorry for being black.. but this is from Drivers side above wheel.
Old Feb 28, 2012 | 07:00 AM
RotaryTherapy's Avatar
Is it your waterpump ?
Old Feb 28, 2012 | 08:42 AM
Z0oMzo0m's Avatar
would it still make noise with the belts off?? its not a loud but still persist. i dont show any signs of leaks, or havent ran hot.
Old Feb 28, 2012 | 10:36 AM
Z0oMzo0m's Avatar
well.. the SHOP says, using a stethoscope, that the noise is from the bell housing of the transmission. by ear you cant hear the difference in noise when pressing, depressing the clutch. You can only hear the throw out bearing get loud and quiet. he is 99.% that's its not the motor and the clutch /bearings are just old and worn.
car has 89k miles on it, installed a light weight flywheel on around 10-15k miles. Clutch feels ok, but guess parts wear eventually.
so need a clutch kit recommendations? more DD, very mild racing, but still like performance.
He mentioned alternator has very mild bearing noise, water pump is quiet, if it were an internal bearing i would no ASAP. he has never really seen a bearing go with no other route cause. The oil has no metal flakes or residue in it.
airlive
Jun 28, 2020 07:46 AM
Luke.s
Sep 30, 2015 05:57 PM
tommy26Germany
Sep 29, 2015 10:33 AM
Jb4ker96
Sep 27, 2015 10:06 PM
