injectors
Old Feb 26, 2012 | 03:57 PM
pingg20's Avatar
Question injectors
hi all , new to this so stick with me ,ive just got a rx8 with a blow engine , got a secound hand one with 26000 on it and fitted it , unexpexedly it started firtst turn, the problem is it dosent seem to have any power top end, its like its restrickted , its fine low revs but just dosnt seem to have anything up top,i ran it flat out and it will only reach 97 mph, im a bit concerned i may have got the injector plugs mixed up a little, can some one tell me if it would still run if i had mixed a couple up . cheers
Old Feb 26, 2012 | 04:31 PM
There are a lot of things that could be wrong...
Check the connections if you have any doubts......it will run at lower loads mostly on the P1 injectors...and until the load and RPM values go up the other injectors are offline
Do you have any CEL codes...if the intake valves are not openning properly it can cause problems as well
Did you check the CAT when you had the engine out? They often fail and you get poor performance...
Start someplace and systematically start checking things till you find it.....
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
OnebaddRx8
Aug 25, 2019 11:34 PM
extreme_rotary
Sep 30, 2015 09:53 AM
Jb4ker96
Sep 27, 2015 10:06 PM
RAE008
Sep 20, 2015 01:32 PM
