DIY urethane motor mounts question
Old Feb 24, 2012 | 08:13 PM
toke_'s Avatar
I ordered the 1 lbs of Shore 60A from McMaster-Carr and it got here a couple days ago and i noticed the box was really light so i opened it up and the quart can was only like 2 fingers deep with urethane and the activator bottle was like half empty too. Is that normal? and is that enough to fill both mounts?
Old Feb 25, 2012 | 01:52 AM
Wind Dance's Avatar
Central Valley RX8
Yes
Old Feb 25, 2012 | 08:25 AM
toke_'s Avatar
ok thank you
Old Mar 10, 2012 | 07:20 AM
60A is too soft, the minimum should be 80A, I am using 94D for racing
Old Mar 10, 2012 | 07:25 AM
bse50's Avatar
#50
72A is fine too, for road racing (edit: A lot depends on the manufacturer. I use a fast hardening compound that, despite its 72a shore isn't really elastic and "soft".)
The important thing is to modify the mount so that the soft "hat" doesn't take all of the load since there's no oil\resonator to absorb the load.
Drill press, 2 bolts and a couple of washers.
Old Mar 10, 2012 | 07:37 AM
You keep saying this but I strongly disagree, once you put urethane in them there is no reason to do that because they can't move enough to tear open. The RH OE mount tears because the combined movement of both the flimsy OE mounts along with the soft diff mounts allows the drivetrain to move excessively (LH collapses and RH lifts). Neither side can move nearly as much (especially if you also go to stiffer rear diff bushings) so this no longer happens*if* you clean the interior out properly and get a good bond with the urethane.
Old Mar 10, 2012 | 07:51 AM
bse50's Avatar
#50
I agree that it won't happen to most but it still "could" happen especially if you throw the car around a lot. The way I see it it's a mod that takes 10 minutes for both sides and has only benefits (either potential or manifest) and no side effects.
You should definitely try it if you haven't already. If you didn't live that far away from me i'd even send you a set i have.
With or without longer bolts and further thread to anchor to this way of filling motor mounts is much better than any readily available commercial mount.
Old Mar 11, 2012 | 10:46 AM
toke_'s Avatar
well my rx8 is automatic so its not the best for racing. and when i took the mounts out they were in perfect condition so i never used the urethane. I think its the transmission mounts that are causing the vibration in the cabin but i asked and no one replied. I dont know how to change the transmission mounts on this car
Old Nov 24, 2012 | 07:32 PM
Nathan Atkins's Avatar
V8 Traitor
The transmission doesn't have mounts per se, the transmission is joined to the rear differential via a "power plant frame" which is essentially a girder that parallels the drive shaft. So basically the motor mounts are all that secure the front of the drive train.
UHATEIT
Mar 31, 2019 05:31 PM
Glaxzor
Aug 21, 2015 09:26 PM
Glaxzor
Aug 21, 2015 07:41 PM
MolecularConcept
Aug 5, 2015 04:43 PM
Obivious
Jul 29, 2015 05:57 PM
