Pop / clunk only when turning right.
Old Feb 18, 2012 | 12:15 AM
Torotor's Avatar
Rotard
04 6spd suspension and rims completely stock.
When turning right at low speeds usually almost all the way to full lock I hear/feel a pop/clunk from the front passenger side. Also happens at moderate speed turning in sometimes.
I've done a bunch of searching and I have replaced the sway bar endlinks. I've greased the sway bar bushings. I've checked all crossmembers and suspension bolts for tightness. I've tried moving the wheel and I don't believe it's a wheel bearing (no play). I can replicate the sound while stationary and turning the wheel to full lock right but its impossible to track down where it's coming from. Please help!
Old Feb 18, 2012 | 03:14 AM
ken-x8's Avatar
Left/right correlation doesn't quite match, but it might be what's described in the "Snapping noise..." service bulletin. Or maybe the "Noise from front..." one.
https://www.rx8club.com/series-i-trouble-shooting-95/tsbs-technical-service-bulletins-183774/
Ken
Old Feb 18, 2012 | 03:40 AM
Torotor's Avatar
Rotard
Ken, I replaced the sway bar end links with OEM ones which was the first tsb u mentioned. I forgot to mention that I already tried cleaning the wheel/rotor surfaces with some emery cloth already. However now that I've read the tsb then I think I will try removing the rotor and doing a better job than 2 mins. I should also mention that this only started happening after taking my wheel off cleaning my ssv. I will report back tomorrow after I get a chance.
Old Feb 20, 2012 | 07:41 AM
audiobull's Avatar
there has also been mention of a loose wheel nut, not being nasty just stating what ive heard as you mentioned removing the wheel, i also have this problem so am watching to see a result.
92trbolzr
May 18, 2025 09:04 AM
cliffkemp
Dec 24, 2024 10:48 AM
Shankapotamus3
Mar 14, 2021 03:53 PM
Jb4ker96
Sep 27, 2015 10:06 PM
Evan Gray
Sep 26, 2015 12:30 PM
