Anyone swap out their battery cables/terminators?
Old Feb 17, 2012 | 02:41 PM
Raevik's Avatar
At some point during the early years of frequent battery swapping, the positive-lead terminator deformed out of a circle shape and won't clamp properly on the battery post.
As an ugly fix, I put a screw into it and coated it in grease. It works, but it will eventually corrode.
I need to replace the terminal on the positive lead. Does this require a whole new cable, or can you get just the terminal itself? Is this a common part to replace? If so, anyone got a link to an aftermarket part?
Mazda wants $35 for it which seems crazy.
Before the accusations start, yes I searched and no I didn't find any discussion on it
Thanks in advance. Man I can't believe I've had this car 8 years...
Old Feb 17, 2012 | 03:10 PM
godesshunter's Avatar
Voids warranties
but seriously...https://www.google.com/#q=replacemen...w=1024&bih=608
Old Feb 17, 2012 | 08:10 PM
wickediii's Avatar
I did it
I just used one from Advance Auto when I installed a kill switch. Haven't had any problems with it and was easy as pie. Only problem was radio/temp/clock didn't work when I reconnected everything. Just unhooked the battery overnight and the next morning everything was working again. (Bought a float and forgot to use it Duh) 2nd time this happened and only thing I have found concerning this is that some of the newer cars have a feature that kills communication of systems for short time as preventive measure against thieves??? Not sure just know it works!
Old Feb 18, 2012 | 09:14 AM
Raevik's Avatar
Originally Posted by godesshunter
Do you feel better about yourself? Smarter? I hope so.
Old Feb 18, 2012 | 09:16 AM
Raevik's Avatar
Thanks wicked. I was just eyeballing a simple replacement part from Advance Auto:
http://www.autozone.com/autozone/par...3_54151_13546_
Cheap as dirt and looked like it would do the trick.
Old Feb 18, 2012 | 09:25 AM
200.mph's Avatar
FULLY SEMI AUTOMATIC
replaced mine with a gold one from advanced but it was a little too wide. 2 min. on the grinder and it fit perfect
Old Feb 18, 2012 | 09:35 AM
ken-x8's Avatar
Is that for the whole cable, of just the clamp? If it's just the clamp, yes, that's crazy. If it's the whole cable, it's a little steep but IMHO inthe long run better than just replacing the clamp.
Ken
Old Feb 18, 2012 | 09:58 AM
Voids warranties
Just poking a little fun. lighten up
Old Feb 18, 2012 | 11:13 PM
For the "terminal" mazda has 3 options.
- just the c0ntact part that connects the battery and the fuse.
- with brand new fuse box everything
- the whole battery harness
For the record, the above is for positive only. There is no replacement part from mazda for the negative, only option is to buy a new harness, find a used one, or go aftermarket. Mazda, are you retarded?
Old Feb 18, 2012 | 11:17 PM
I laugh, a lot, i admit.
Old Feb 19, 2012 | 01:17 PM
wickediii's Avatar
Smarter and better thank you
lol Gotta give credit where it is due tho, everything I am doing is cause this site gives awesome info on everything about my baby! People still tell me I cant, shouldn't or will screw up but I just keep proving them wrong! Just wish they stop trying to be right by tripping me up. Success is a wonderful revenge!
92trbolzr
May 18, 2025 09:04 AM
cliffkemp
Dec 24, 2024 10:48 AM
Shankapotamus3
Mar 14, 2021 03:53 PM
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
Evan Gray
Sep 26, 2015 12:30 PM
