Removing stock air filter box!!!
Old Feb 17, 2012 | 12:21 PM
Zeuscraig1's Avatar
Unhappy Removing stock air filter box!!!
Ok I have search found nothing .
I am trying to install green cotton induction kit
For rx8 53 plate. It's a uk right hand drive car 60,000 miles. I noticed
When I popped the air filter box up and removed the
Pipe behind it. Took the maf off also there is a small tube
That goes through a hole in the box which I believe is the
Oil pan attached to the bottom of the air filter. I can't get this
Wire/tube out without cutting it or the oilpan/air box. I didn't really
Want to do that. Anyone Know what am talking about. Apparently this tube is not in 05 Plate rx8 so they must have relocated it.
Is there anyway of sorting this out so I can completely remove the
Box. Please help thx
Old Feb 17, 2012 | 12:49 PM
1.3_LittersOfFurry's Avatar
Flame On!
Are you talking about the small metal vacuum tube that's in the air box tray??
If so, that tube is for the VFAD system. Not sure if your car uses that system or not, most people remove the VFAD, it's only purpose is to keep the intake quiet at low rpms.
Old Feb 17, 2012 | 01:11 PM
Atilla's Avatar
I am THAT guy
wat
pictures would help
Old Feb 17, 2012 | 01:13 PM
Zeuscraig1's Avatar
It like a vacuum tube yeah. But also attaches to a small black
Box then goes through back of air box then round to front of car.
I was going to cut though the plastic oil catch can at the bottom of
The air box to get it out then silicone it back together? Just incase I may
Need to resort back to stock air filter. What's your oppinions. And is what you
Said exactly what it is and is it important?
Old Feb 17, 2012 | 01:16 PM
Zeuscraig1's Avatar
I'll try and get pictures 2moro. Night time now in uk and I have no torch
xexok's Avatar
Just disconnect it at the several areas it connects with hoses. There should be some little metal clips that hold the hoses to that box.
To me it sounds like you are describing the VFAD system with the small hollow black "box" thats attached to the intake tube.
ironj221
36
Jan 20, 2026 08:28 PM
uZu
Dec 30, 2015 12:35 PM
GK1707
Dec 2, 2015 10:01 AM
cschoeps
Aug 6, 2015 12:44 PM
MrORAN6E
Jul 24, 2015 09:32 AM
